fatal error LNK1104
Heli_N_
Dear all,
Recently I am getting the following error when trying to develop FORTRAN code using Microsolft Visual Studio 2010 Shell installed on a Microsoft Win7 Professional.
Error 1  fatal error LNK1104: cannot open file 'x64\Debug\myExectuable.exe' LINK
I´ve tried to manually delete the myExecutable.exe in the debug folder, but the executable keeps re-appearing and I keep getting the same error.
I have also tried to go to services.msc and go to System Application and set the initiation to manual, but this did not help either.
These are the solutions I had searched so far on Internet.  Sometimes when I try to rebuild the above error appears and sometimes it simply does not.
Does anybody know what should I fix to get rid of this error?
Thanks in Advance for your help,
Les_Neilson
Valued Contributor II
Is there an instance of myExecutable.exe still running in the background?
If so you need to kill it and run the build again.
Les
Heli_N_
Dear Les,
Thanks for your reply.  I do not see the myExectuable.exe running under the windows process in order to kill it.
Also I do not want to kill it manually each time this happens. Is there any other fix ? and why does this happen at all ? I did not have this problem before. This is happening newly.
Thanks for your replies.
