[HELP] Calling geev
terranigmus
Hello.
I am trying to call the geev routine to get the eigenvalues of a 9 x 9 double precision complex matrix, namely a hamilton matrix in fortran 95.
The documentation says
call geev(a, w [,vl] [,vr] [,info])
and my call is
call geev(hamilton,eigen)
where "eigen" is a (1:9) array.
Compiling works but I get a segmentation fault when running the program.
Any help?
Sorry if this is in the wrong section.
mecej4
You probably wanted to call the Fortran 95 interface. If you do not include
USE mkl95_lapack
in your source code, your program may link but fail with access violations at run time, because there are many overloaded routine names, and the Fortran 77 routine will probably crash if called with the Fortran 95 argument list.
terranigmus
Getting
undefined reference to `zgeev_mkl95_'
now :(
I am an amateur here but could it be because I am saving as .f90 ? So ifort doesn't see it as Fortran 95 ?
TimP
No, it appears that the llinker wasn't asked to search the MKL libraries. ifort doesn't even provide for .f95 files by default.
It could be as simple as adding -mkl. Beyond that, the link advisor at the top of the MKL forum comes into play.
mecej4
The file suffix is not used in selecting which Fortran standard to use as the reference. It is only used to signify whether the source file is fixed- or free-format. Secondly, the "undefined reference" is a linker error, not a compiler error.
You can use the compiler option -mkl and the linker options -lmkl_lapack95 -lmkl_blas95. Please consult the Link-Line-Advisor.
