29650 Discussions
Intel Fortran with Visual Studio 2010 guide..
eubie
I am new to fortran, so I apologize in advance if my question is lame.Is there any guide related to how to mix C++ and Fortran using Intel Fortran compiler and visual studio? A C clone of quadpack crashed on some inputs while the fortran one returns a value, so I need to use the fortran version in my C app.
Any help on these is much appreciated, I have a tight academic deadline to meet and GSL just gave up on me. Many thanks,
Daniel
mecej4
Given that you are not experienced in Fortran, you may exchange one problem for a bigger one by doing what you described.
Show the Quadpack routine references in your C code, along with the declarations of the function arguments, and I can perhaps suggest how to link to Quadpack in a Fortran library or DLL.
eubie
Hello, thanks for the answer. I have downloaded quadpack from
and developed a piece of fortran code to call qagi. The code is
[fortran]real function MomentWei(kappa, p, v) COMMON/weibullCommon/ CKAPPA,CP real CKAPPA real CP real kappa real p real v real xi real gammafact real res real error integer evaluations integer errorindication real, external :: logpweibulIntegrand CKAPPA = kappa CP = p if ( v .ne. 0 ) then ! v != 0 xi = gammafact( 1.0 + 1.0/kappa) res = (1.0/xi) ** (v*p) * gammafact( 1.0 + v*p/kappa) else ! v == 0 call qagi(logpweibulIntegrand, 0.0, 1, 1e-08, 1e-08, res, error, evaluations, errorindication ) if ( errorindication .lt. 0 ) stop 'MomentWei >>> Abnormal qagi termination' end if if ( isnan(res) ) stop 'MomentWei >>> Integral is a NaN' MomentWei = res end [/fortran]
where "logpweibulIntegrand" is some function of the correct type. I tested the code, it works. Now I have a C app...
[cpp]
#include
extern "C"
	extern float MOMENTWEI(float * kappa, float * p, float * x);
int main(void)
	float kappa = 1.0;
	float p = 2.0;
    float x = 0.5;
	float Res;
	Res = MOMENTWEI( & kappa, & p, & x);
	return 0;
};[/cpp]
and when I use MSVC 2010 and include a directory with intel fortran libraries to the linking process, all is OK. However, when I use Intel C Compiler from MSVC 2010, I getlinker errors, namely ...
Link:
xilink: executing 'link'
LIBCMTD.lib(dbgheap.obj) : error LNK2005: __CrtSetCheckCount already defined in MSVCRTD.lib(MSVCR100D.dll)
LIBCMTD.lib(invarg.obj) : error LNK2005: __invoke_watson already defined in MSVCRTD.lib(MSVCR100D.dll)
LIBCMTD.lib(crt0dat.obj) : error LNK2005: _exit already defined in MSVCRTD.lib(MSVCR100D.dll)
LIBCMTD.lib(crt0dat.obj) : error LNK2005: __exit already defined in MSVCRTD.lib(MSVCR100D.dll)
LIBCMTD.lib(crt0dat.obj) : error LNK2005: __cexit already defined in MSVCRTD.lib(MSVCR100D.dll)
The app runs OK, but speed is of essence in here, so I would like to have the possibility to compile with ICC. If it is straight forward, what Im doing wrong, please tell me.
Thank you again,
Daniel
You have the dread disease "Mixed C Library Syndrome". Fortunately, science has a cure. The C project and the Fortran project are asking for different types of run-time library. C defaults to DLL, where Fortran defaults to static. In your Fortran project, change property Fortran > Libraries > Use runtime library" to "Multithreaded Debug DLL" (for the Debug configuration) and "Multithreaded DLL" for Release.
eubie
Thank you both!
Daniel
