HELP>>>>>???
wai88iaw
why i can compile a project with somefortran modules andIMSL library....but cannot built it>>> it say error??
What is the exact and complete text of the error message?
When using IMSL, you need to specify the IMSL libraries when linking. There are several ways of doing this, and which one is best for you depends on which compiler version you are using. If you are using Intel Visual Fortran, this is explained in the section on IMSL in the Libraries chapter of the Building Applications manual.
wai88iaw
'console1.exe': Loaded 'C:WINNTsystem32NTDLL.DLL', Cannot find or open a required DBG file.
'console1.exe': Loaded 'C:WINNTsystem32ADVAPI32.DLL', Cannot find or open a required DBG file.
'console1.exe': Loaded 'C:WINNTsystem32KERNEL32.DLL', Cannot find or open a required DBG file.
'console1.exe': Loaded 'C:WINNTsystem32 pcrt4.dll', Cannot find or open a required DBG file.
HERE is the error message, how to fix it>>>>
Those are not error messages - ignore them.
