Symptom: "system()" does not release handles and related resources. It can be seen from task manager or any other process monitors.
Tested using the following code:
program sysintel
use ifport
implicit none
integer i, iret
do i = 1, 10000
iret=system('echo 1 > dump')
end do
end program sysintel
As the iteration goes on, the system resource gets exhausted. Same codes written in C or Fortran using dfport are all working properly. Is this a bug in IVF?
Xgli,
I have seen a similar problem with my application which uses the Array Visualizer to displaycomplicated3D graphs of a simulation as the simulation runs. The Array Visualizer has a library that links into the applicaton but the instanciation of the Display driver isrun as a seperate application. The AV library launches the AV Display driver once then communicates with the AD driver somehow (looks like shared memory).
As my application runs, I see what looks like a slow memory leak.
I do not know if this is a Windows problem or something to do with what is called via the AV library.
As far as I can determine on my side the leak occures in the AV Display driver. Because I can delete the instance of the AD Display driver while my application runs, the system reclaims the memory, then I can click on a button on my app to instruct it to open a new display window. This can be done while the simulation continues to run.
Jim Dempsey
