Heap Error
franzw82
when executing a Fortran program (32-bit) I get the error message
"Fatal Error: Can not initiate the Heap"
The code is really large and I have not succeeded in producing a minimal example where the error occurs. My only clue is that the error occurs more or less directly after the allocation of a larger memory segment via malloc fails (malloc returns 0).
I first thought this is a bug in the compiler 2011.9.300. So I went back to version 11.1.072, but unfortunately the error still occurs. I have tried several runtime checks (check for null pointers, check array and string bounds, etc.), however these checks are all ok. I also tried Intel Inspector XE 2011 which could not find the problem -- it says that it ran out of memory.
Any ideas for tracking this down? Thanks in advance.
Franz
My guess is that you've run out of address space. I see no evidence of a compiler bug in what you have posted so far. How much memory are you allocating? Why are you using malloc rather than ALLOCATE?
SergeyKostrov
Valued Contributor II
Quoting franzw82
1. On32-bit Windows platformswithout AWE an application can not allocate more than 2GB of memory
2. On32-bit Windows platformswith AWE an application can allocate more than 2GB of memoryup to ~3GB
Here are some recommendations:
1. Try to use the Task Manager and monitor how much memory isallocated when your application gets the error.
The values to look at are as follows:
Performance property page:
Commit Charge (K) -> Peak
Physical Memory (K) -> Available
Processes property page ( You need to select columns ):
Mem Usage
VM Size
2.Verifysize of the Virtual Memory file and increase if needed ( on my system I have 1,024MB for Initialand 4,096MB for Maximum)
3. Try to call a'GetLastError' Win32 API function after a'malloc' calland in your casean error codehas
to be 8( ERROR_NOT_ENOUGTH_MEMORY ) ( this is simply to verify )
4. Try to increase Heap ( Reserve / Commit ) values.16MB values worked well in a similar caseand it isconfirmedby
a FORTRAN developer 2 days ago but in your case it is still not clear how much memory your application attempts to allocate
Note: AWE - Address Windowing Extensions
