Kindly help me in understanding this error, what could be the possible cause?
%FOR-E-ADJARRDIM, adjustable array dimension error
%TRACE-E-TRACEBACK, symbolic stack dump follows
It is occuring at line 173, a subroutine call.
Naveed
Naveed
It basically means the dimensions on the subroutine's adjustable array doesn't makes sense, for example if you
integer array(10), size
call sub (array, size)
and sub is declared as
subroutine sub (array, size)
integer array(size), size
If you do something like set size to zero or something huge you might see this error.
James
James
