Help With EOSHIFT
Ernie_P_1
I have an array as follows:
ARRAY1(50,78)
I want to perform an EOSHIFT for only one value of dimension 1. For example, I want to shift all of the following values:
ARRAY1(16,1:78)
My example has 16 but I want this to be dynamic. I want to leave all other values unchanged. ARRAY1(1:15,1:78) and ARRAY1(17:50,1:78) should be unchanged.
I think I can use this:
INTEGER SHIFT(50)
INTEGER MY_INT
SHIFT=0
MY_INT = 16
SHIFT(MY_INT) = 1
ARRAY1 = EOSHIFT(ARRAY1, SHIFT, DIM=2)
I'm pretty sure this will work butis therea more efficient way?
Can I eliminate the SHIFT array with 50 elements?
Ernie P.
IanH
Perhaps
[fortran]array1(my_int,:) = EOSHIFT(array1(my_int,:), 1)[/fortran]
The compiler may (?) still create temporary arrays for the expression and assignment, but at least it's reasonably clear from the line of source what your intent is.
IanH
Perhaps
Ernie_P_1
IanH,
Works. Thanks a lot!
Ernie P.
