Help file more up to date than compiler
Andrew_Smith
Valued Contributor I
The latest help says a type bound procedure can have the [NON]OVERRIDABLE attribute but it gives a compiler error.
[fortran]module ParentType
   implicit none
   type AType
      contains
         procedure, NONOVERRIDABLE :: doSomething
   end type
contains
   subroutine doSomething(item)
      class(AType), intent(inout) :: item
   end subroutine
end module
[/fortran]
Compiling with Intel(R) Visual Fortran Compiler XE 14.0.1.139 [IA-32]...
Console1.f90
D:\temp\Console1\Console1\Console1.f90(6): error #8172: This is not a valid attribute for the procedure component definition statement. [NONOVERRIDABLE]
compilation aborted for D:\temp\Console1\Console1\Console1.f90 (code 1)
IanH
Looks like a "spelling" mistake in the documentation.  The keyword is NON_OVERRIDABLE.  There's no OVERRIDABLE keyword.
FortranFan
It's clearly a typo in Intel's help system.
NON_OVERRIDABLE is the right option; and as Ian mentioned, OVERRIDABLE is not a valid keyword.
When in doubt, refer to Fortran 2003 and 2008 standards documentation.
NON_OVERRIDABLE is indeed available in Intel Fortran compiler; I've been using it extensively for a while now.
Steven_L_Intel1
I'll have this corrected in the documentation.  Thanks for calling it to our attention.
