Help with AdjustTokenPrivileges
Intel_C_Intel
I would like to have a program reboot the machine after it has finished. The routine ExitWindowsEx appears todo this, however the session token(?) must have the SE_ShutDown_Name privilege enabled. Since ExitWindowsEx will LogOff, but not ShutDown or ReBoot, I assume this privilege is not enabled. The routine AdjustPrivilegeTokens can be used to change this, but I am quickly descending into theinferno and seek counsel.
Is there an easier way?
Does anyone have a code example?
Thanks, Cliff
Jugoslav_Dujic
Valued Contributor II
Um, I deem Windows security APIs as a big black hole...
Alittle Googling, however, reveals this list -- the second link, for one, contains a code sample.
Jugoslav
llynisa
There is an example at ...df98samplesadvancedWin32ExitWin.
Alan
Intel_C_Intel
Thanks to you both. I have the codeworking now for the most part and will share it here when finished.
Thanks again, Cliff
Message Edited by frieler on 02-25-2004 08:20 AM
garyscott
Hi, not sure what you mean by "black hole", but they sure are messy (although they're messy everywhere).
Jugoslav_Dujic
Yes, I meant they were messy.
That observation probably partly comes from my ignorance; however, once one gets used to basics, it's usually relatively easy to make a breakthrough in another field of Win32 programming. However, once I needed something from security APIs, I got lost very quickly in documentation -- all the talk about SIDs, privileges, tokens, impersonation... didn't make sense to me, so I gave up. I doubt I'll touch it again without anadvance reading of something like J. Richter's "Advanced Windows"... or just recycle someone other's code :smileywink:.
Jugoslav
Intel_C_Intel
The attached code is a simple "Session Disposition" utility.
I have kept the functionality of this sample to a minimum and hope that the programming style is clear enough.
When one of my remote processes has ended, I execute this program to cleanup after myself. It can "LogOff", "ShutDown", "PowerOff" or "ReBoot", controlled by a command line string, i.e.,
C:> Dispose LogOff
Although this code only required afew calls to Win32, I agree with Jugoslav.The documentation isn't sufficiently clear or consistent, and without the code examples I could not have even gotten this simple utility working.
Thanks again to Jugoslav and Alan!
Intel_C_Intel
Next issue.........
The code functions well, but only if the user session is active. If a screen saver has activated and requires a password, the code fails. This means that I need to interact with the screen-saver and it's security hooks, or find some other means.
Any ideas or suggestions?
Thanks, Cliff
Jugoslav_Dujic
I assume you want to shutdown the computer after a long number crunching?
You may take a look at SystemParametersInfo -> SPI_SETSCREENSAVEACTIVE or related flags. I know it's a cludge, though... but I'm not sure if there's the "right" way, as Windows keeps some security-related things unbreakable (e.g. there's LockWorkstation but there's no UnlockWorkstation and there may be no way to find a way around).
Still, you may want to ask/search Google groups such as comp.os.ms-windows.programmer.win32 or microsoft.public.platformsdk.security.
Jugoslav
Intel_C_Intel
Jugoslav,
It appears that
controls whether or not the screensaver (and locking mechanism) will activate. While disabling this would solve the problem for installations with good physical security, in my environment I don't want that (and don't have the authorization).
Your suggestion has still been of great value, because while reading about SystemParametersInfo, I found the function InitiateSystemShutDown. It appears to allow system shutdown and reboot even if the workstation is locked.It still requires the SE_ShutDown_Name privilege be enabled, so the previous answers in this thread will also be used. The net result is that I can do everything I wanted, except simply logging off a locked workstation. Since the result of a reboot is the same login screen presented tothe next user, I anticipate little real difference.
I'll post the resulting code when I have it working.
Thanks, Cliff
Message Edited by frieler on 03-03-2004 04:02 PM
