Help with Intel fortran building error with PETSc
Wee_Beng_T_
I am using ifort version 15.0.1 to compile and build my code with the open source PETSc and MPI
Compiling has no error msg but during building, I got the errors below, though in the end the build completed with a working a.out. However, I'm still worried there's some underlying problems. What do these errors mean?
ipo: warning #11021: unresolved xcb_connection_has_error
        Referenced in /usr/lib64/libX11.so
Wee_Beng_T_
Here are some more errors such as:
ipo: warning #11021: unresolved __xmlGenericError
        Referenced in /app1/centos6.3/Intel/mvapich2-2.1/lib/libmpi.so
However, I can't post them since it says:
Your submission has triggered the spam filter and will not be accepted. If you feel this is in error, please report that you are blocked.
Steven_L_Intel1
It looks as if you need to add some additional library to the link step.  I don't know which library defines those symbols.
Wee_Beng_T_
ok thanks anyway.
