29486 Discussions
How can I access the array by its storage address
liu_huafei
       I have a question about the usages of function loc or c_loc.
I want to access the array a in a subroutine.
I konw that the loc or c_loc can gets the storage address of the variable.
But how to use its address to access its data .( not using 'use datamod')
In the C language , I can manage it. Can we do it in Fortran.
      Thanks in advance!
module datamod
implicit none
   real,allocatable,save :: a(:)
   real,allocatable,save :: b(:,:)
end module datamod
program main
use datamod
implicit none
integer :: i
integer :: loc_a,loc_b
!allocate a ----------------------------------------
allocate(a(10))
do i=1,10
 a(i) = real(i)
end do
! get the address of a
loc_a = loc(a)
write(*,*) 'the address of a storage',loc_a
! how can I get the data of array 'a' by its address
end program
The standard way to do this:
[fortran]
program main
use datamod
use, intrinsic :: iso_c_binding
implicit none
integer :: i
type(c_ptr) :: loc_a
real, pointer :: ap(:)
allocate(a(10))
do i=1,10
 a(i) = real(i)
end do
loc_a = c_loc(a)
call c_f_pointer(loc_a, ap, [10])
print *, ap
end program
[/fortran]
In this case I have used c_loc. If you want to use an integer to hold the address, you must declare it as integer(c_intptr_t) where c_intptr_t comes from module iso_c_binding. You can also use integer(int_ptr_kind()). If you use an integer pointer, replace loc_a in the call to c_f_pointer with transfer(loc_a, c_null_ptr).
[fortran]
program main
use datamod
implicit none
integer :: i
allocate(a(10))
do i=1,10
 a(i) = real(i)
end do
loc_a = c_loc(a)
print *, ap
end program
[/fortran]
liu_huafei
Thanks for your answer.
