I want an include file that has ONE LINE:
PARAMETER NDA=100
The purpose is to be able to re-dimension all the routines that use this PARAMETER in my source code,
by changing this one line. How do I make an INCLUDE file that the compiler can accept ?
I tried making it with "open office," but your Fortran compiler generated all kinds of weird errors when I use
that editor to make it.
How can I place this include file so that all my routines can easily access it ?
The routines are in different folders, so I would like to avoid having to give a different syntax in every folder,
if possible.
I was unable to get priority support for this issue.
Just use Notepad. OpenOffice probably created some Office document format.
You can use /Ipath-to-folder (That's a capital I, not lowercase L) to specify where your include file is, and any INCLUDE that just gives the name will find it.
Where would I put the IPATH? I had trouble finding that one.
Steve gave you the syntax for specifying a non-default include path when running Ifort from the command line. The "/I" identifies the specific option, and what follows is the argument to the option, which is the (absolute or relative) path to the directory containing the files to be included. If, for example, the include file is in .\incl, the command option is /Iincl.
If you are using Visual Studio to build, instead of the command window, there is a corresponding item in the project properties that you can set.
A better route for you to consider is to use a module to contain global parameters or global runtime values that are set at runtime (e.g. from command line options).
! File GlobalParameters.f90
module GlobalParameters
! what you want for compile time values
integer, parameter :: DefaultN = 100
end module GlobalParameters
! End file GlobalParameters.f90
!---------- next file ---------------
! File GlobalVariables.f90
module GlobalVariables
use GlobalParameters
! what you want for run time values
integer :: N
character(256) :: buffer
contains
subroutine parseCommandLine
implicit none
if(COMMAND_ARGUMENT_COUNT() == 0) then
N = DefaultN
else
! ... your code here to parse arguments
call GET_COMMAND_ARGUMENT(1, buffer)
read(buffer,'(I)') N
! ... additional arguments
endif
end subroutine parseCommandLine
end module GlobalVariables
! End file GlobalVariables.f90
! File Globals.f90
module Globals
use GlobalVariables
end module Globals
! End file Globals.f90
! GlobalExample.f90
program GlobalExample
use Globals
implicit none
call parseCommandLine
call FOO
call FEE
end program GlobalExample
subroutine FOO
use Globals
real :: array(N)
print *, size(array)
end subroutine FOO
subroutine FEE
use Globals
real :: array(DefaultN)
end subroutine FEE
Output:
200
100
Jim Dempsey
For your simplified
module m_NDA
integer, parameter :: NDA = 100
end module m_NDA
subroutine foo
use m_NDA
implicit none
real :: array(NDA)
Jim Dempsey
Just create a text file with the extension .fi or .inc
The in your code use an `include` statement similar to the example below.
include 'constants.inc'
But again, I have to agree with the other comments, to make a module with the constant values instead of reading an include file in each source.
this was VERY HELPFUL.
Thanks to all of you ! !
Note that the form of PARAMETER quoted above (no colons or parens) was an extension prior to F90 which was supported by several compilers. It ought to be rejected if a /stand option is set. There were some nasty variations possible in data typing which you might have hoped would surface under IMPLICIT NONE (also an extension at the time, but one well enough proven to be adopted as standard).
