29341 Discussions
How do I pass double precision variables into single precision subroutine?
david_sallngc_com
dannycat
If you are passing by value you can use the real() function in the subroutine argument. If however you wish to obtain a real value from the subroutine you can use a local real(8) dummy argument and then equate to your real(4) variable.
real(8) :: dValue
Call Sub(real(dValue))
or:
real(4) :: fValue
real(8) :: dValue
call Sub(dValue)
fValue = real(dValue)
david_sallngc_com
Quoting - dannycat
real(8) :: dValue
or:
real(4) :: fValue
real(8) :: dValue
call Sub(dValue)
Hi dannycat!
I can't believe it but my entire question was missing! I need to give you a bit more information. I am trying to pass double precision variables into a single precision subroutine. After the calculation in the subroutine (in single precision), I need to pass the data back to the calling routine in double precision. for example,
implicit none
real*8 a, b(10)
complex*16 c(5,3)
call xxx(a, b, c)
end
subroutine xxx(a, b, c)
implicit none
real a, b(10)
complex c(5,3)
return
end
I doing a lot of coumptations in subroutine xxx and need to return with a complex matrix c that is double precision in the calling routine.
Thanks for your help!
Sincerely,
David
dannycat
Hi dannycat!
implicit none
real*8 a, b(10)
complex*16 c(5,3)
call xxx(a, b, c)
end
implicit none
real a, b(10)
complex c(5,3)
return
end
Sincerely,
David
David,
It would be neater to make a copy of your subroutine and convert it to double precision. Both could be placed in a module and then you can either create a generic procedure which calls the appropriate precision or use the optional arguments to specify the passed variable kinds.
module xxxlib
contains
interface xxx
module procedure xxx4
module procedure xxx8
end inteface
subroutine xxx4(a,b,c)
end subroutine
subroutine xxx8(a,b,c)
end subroutine
end module
If you can't change the subroutine I would just copy variables into real(4) type, call subroutine and then copy back to real(8)
real(4) a4,b4(10)
complex c4
a4 = real(a)
b4 = real(b)
c4 = cmplx(c)
call xxx(a4,b4,c4)
a = dble(a4)
b = dble(b4)
c = dcmplx(c4)
You will lose precision unless you use a double precision subroutine.
ender01
Quoting - dannycat
David,
module xxxlib
contains
interface xxx
end inteface
end subroutine
end subroutine
end module
real(4) a4,b4(10)
complex c4
a4 = real(a)
b4 = real(b)
c4 = cmplx(c)
call xxx(a4,b4,c4)
a = dble(a4)
b = dble(b4)
c = dcmplx(c4)
David raises an excellent point, why do you want to convert to single precision? I would seriously consider converting the called procedure to double precision if you have access to the source. In this era of cheap memory there is rarely a good reason to use single precision and usually some pretty good reasons not to.
