29297 Discussions
How do you get a multi-line message box
Intel_C_Intel
I can get a multiline message box by including in the text.
But this doesn't work if I want to buld the message text from a combination of smaller text items.
I'm sure there must be a way to do this.
David
msg='This is line 1
This is line 2'c
iret=MessageBox(0,msg,'Title'c,MB_ICONINFORMATION)
msg='This is line 1
'//'This is line 2'c
The first example gives:
This is line 1
This is line 2
The second example gives:
This is line 1 This is line 2
Here's how I do it:
CHARACTER(2), PARAMETER :: CRLF = CHAR(13)//CHAR(10)
msg = 'This is line 1'//CRLF//'This is line 2'C
You can even build up the line across several statements like this:
msg = trim(msg)//CRLF//'This is line 2'C
Note that only the last line uses the C string type - alternatively you could concatenate CHAR(0).
Steve
Intel_C_Intel
David
