29487 Discussions
How to Allocate structure data in subroutine and return data through pointer ref
smk
Dear Forum,
I'm having trouble figuring out how to properly allocate my defined type in a subroutine and return the data to the main program using a structure pointer passed to the subroutine. I suspect I am making an easy mistake but I can't find the right way to set this up and help would be greatly appreciated.
compiled, version 18.0.1.156 Build 20171018
ifort datTest.f90
On execute I get: "forrtl: severe (157): Program Exception - access violation" as soon as I try to access structure.
Test code, datTest.f90, below.
Thanks!
module Test
implicit none
type myArrObj
real , allocatable, dimension(:):: dat
end type myArrObj
contains
subroutine getDataPtr(dPtr)
real, pointer , dimension(:) , intent(out)::dPtr
real , allocatable, target, dimension(:):: mydata
allocate(mydata(10))
mydata=7.0
dPtr=>mydata
return
end subroutine getDataPtr
subroutine getDataObject(dPtr)
type(myArrObj), pointer, intent(out)::dPtr
type(myArrObj), target:: mydata
allocate(mydata%dat(10))
mydata%dat=5.0
dPtr=>mydata
print *, dPtr%dat ! Allocation happend and data is here
return
end subroutine getDataObject
end module Test
program datTest
use Test
type(myArrObj), pointer ::ObjPtr=>null()
real, pointer, dimension(:) :: ArrayPtr=>null()
call getDataPtr(ArrayPtr)
print *, ArrayPtr ! Allocation done in subroutine and data returns w pointer
call getDataObject(ObjPtr)
print *, ObjPtr%dat ! forrtl: severe (157): Program Exception - access violation
end program datTest
FortranFan
@keller, scott,
Note the two allocated objects in your two subroutines, getDataPtr and getDataObject, are "local" to those procedures and when the execution returns from those subprograms, those objects can get destroyed.  If you intended for your "mydata" objects to be "global: objects instead with "saved" status, you may consider explicit instructions for the same by placing them in your MODULE itself i.e., before the CONTAINS section:
module Test
   implicit none
   type myArrObj
      real , allocatable, dimension(:) :: dat
   end type myArrObj
   ! Declare "global" objects that are saved
   real, allocatable, target, save :: mydata1(:)
   type(myArrObj), target, save :: mydata2
contains
      allocate(mydata1(10))
      mydata1 = 7.0
      dPtr => mydata1
      return
      allocate(mydata2%dat(10))
      mydata2%dat = 5.0
      dPtr => mydata2
      return
end module Test
program datTest
   use Test
   type(myArrObj), pointer :: ObjPtr => null()
   real, pointer, dimension(:) :: ArrayPtr => null()
end program datTest
Separately, you may want to consider moving away from POINTER attribute and work with ALLOCATABLE attribute in Fortran and move away from "globally" saved objects and rather have data in objects allocated in the calling code and given your use of OO-like getter procedures, perhaps you may want to look into OO features in Fortran and employ them instead.  The references in this Dr Fortran blog can be helpful for details: https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world
FortranFan
@keller, scott,
module Test
   implicit none
   type myArrObj
   end type myArrObj
contains
      mydata1 = 7.0
      dPtr => mydata1
      return
      mydata2%dat = 5.0
      dPtr => mydata2
      return
end module Test
program datTest
   use Test
end program datTest
smk
@FortranFan: Thanks so much for your post, it helped me understand the deallocate behavior in the subroutine better and your comments pointed me in the direction I was looking for. It was even easier to do what I was hoping.  I'm attaching the modified version in case anyone else is interested in the same issue.
module Test
implicit none
type myArrObj
end type myArrObj
contains
function getDataObject()
type(myArrObj) :: getDataObject
allocate(getDataObject%dat(10))
getDataObject%dat=5.0
return
end function getDataObject
end module Test
program datTest
use Test
type(myArrObj) ,target:: Obj
Obj= getDataObject()
print *, Obj%dat
end program datTest
