29386 Discussions
How to add Export command to a VS DLL project's link step to add symbol from a precompiled .OBJ file
anthonyrichards
New Contributor III
I have a .DLL which requires linking in a precompiled object .OBJ from a third party which contains a symbol that must be exported.
How can you add the required export command to the link step within Visual Studio (I never use NMAKE) so that the DLL's export table contains the required additional symbol?
Wendy_Doerner__Intel
Valued Contributor I
I think you want the /DEF linker command. See this link to the Microsoft website to setup the export variable names. And this link to see how to use /Def to specify the file to import Export names from.
This is assuming that the the .obj was not written with in our compiler and so you can not use DLLExport/Import commands in the source.
Wendy
Attaching or including files in a post
anthonyrichards
New Contributor III
Thanks. It is a C-program.
Under project properties...configuration properties...linker...command line, I added /export:theexportname and that appears to have worked!
