29652 Discussions
Internal error on SSA (Static Security Analysis)
lklawrie
Error 239 error #10338: Static security analysis has failed because of an internal error(code 1). Analysis results are likely to be incomplete.
Any hints on what to do? This, of course, is my very large project. I need to bundle it for premier support anyway, for other internal errors.
Linda
Wendy_Doerner__Intel
Valued Contributor I
Linda,
Is this error coming from the Intel Compiler or Inspector? Yes we will need to see the project zipped up with all the project files if from Microsoft Visual Studio or command lines if you are invoking from the command line.
You can submit it here by attaching to the issue (I can take the thread private so only we see) or you can do it on premier.intel.com.
I would suspect it might be related to the size of the project.
lklawrie
From the compiler as it tries to "build for SSA".
You can piggy back on issue 646678 which is the same project but for an internal compiler error on Maximize Speed Optimization level (you may have to reset the opt level on the one module). Or I can submit a separate issue for the SSA.
I do not have Inspector - but that shouldn't make a difference, right?
Linda
Linda,
Annalee who is working on your premier support issue is going to investigate this SSA error too and will reply to this thread.
Wendy
Attaching or including files in a post
Anonymous66
Hi Linda,
I got a different error code, but I was able to reproduce your error. I'll work with you through the Premier Support issue on this problem.
Annalee
lklawrie
Sounds good.
Linda
