29252 Discussions
How to avoid prepend underscore when linking a fortran lib from C++?
Christer
I have a problem when using a fortran lib (actually a dll) from C++
I have created a fortran-dll andI want touse this fortran-dll in a C++ project.
But when linking my c++ project I receieve the error message :
unresolved external symbol _pt_h_gas
A short description of my project:
  • In my fortran dll I am using the following attributes:
  • Real*8 Function pt_h_gas(p , t, y1, y2, y3, y4, y5, y6, y7,unit)
    C Dll directives
    !dec$ attributes dllexport :: pt_h_gas
    !dec$ attributes alias:'pt_h_gas' :: pt_h_gas
    !dec$ attributes value:: p,t,y1,y2,y3,y4,y5,y6,y7,unit
    In the C++ project I have added the library from the fortran project and used the following code to use the function (this is just the test code)
extern "C"
double __stdcall pt_h_gas(double p ,double t,float SO2,float H2O,float CO2,float N2,float O2,
float Ar,float He,float unit);
#include "stdafx.h"
int _tmain(int argc, _TCHAR* argv[])
float SO2 , H2O, CO2, N2, O2,Ar,He, unit;
double enthalpy;
double p,t;
enthalpy = PT_H_GAS(p ,t,SO2,H2O,CO2,N2,O2,Ar, He,unit);
(I can use __cdecl and I get the samme message)
The main problem is C++, it will add an underscore as prefix to function names when linking but the fortran lib/dll does not have any prefix.
I want to avoid this prefix and my question is there any settings/options pragmaor any other way to avoid the prefix?
I am using Visual Studio 2005 for C++
I know I can avoid this problemby deleting the line !dec$ attributes alias: and use function name PT_H_GAS instead in the c++ code (I have tested) but I really want to avoid this.
The reason for this is that the fortran dll/lib is used in other applications (functions for Excel etc) and isdistributed to many users. Then I have to change these programs as they work without any underscore prefix. The solution to have different fortran dll:s/libs is not acceptablefor quality reason it is said.
Maybe it is impossible to solve but to avoid a lot of work I try help from you!
TimP
If you have matching C (or C++) and Fortran compilers, there will not be a discrepancy on account of leading underscores. However, ifort for Windows will default to upper case linkage identifiers without underscore conflicts with Windows C. You could correct the case in a standard compliant manner by specifying an iso_c_binding Fortran interface, and removing the _stdcall on the C side. Microsoft dropped full support for stdcall about 7 years ago, and so the cases where it could be used are limited. If you are still using CVF, of course, you have to deal with stdcall.
At least two problems here. 1) You have __stdcall in the C++ declaration but Intel Fortran uses the C mechanism. Remove it. 2) You spell the routine name in lowercase in the C++ declaration but call it with the uppercase name. As far as C++ is concerned, these are two separate routines.
To fix. Take out the __stdcall and change the case of the declaration to be uppercase. Remove the ALIAS directive in the Fortran code.
Alternative. This for the C++:
[cpp]extern "C"
double pt_h_gas(double p ,double t,float SO2,float H2O,float CO2,float N2,float O2,
#include "stdafx.h"
double enthalpy;
double p,t;
enthalpy = pt_h_gas (p ,t,SO2,H2O,CO2,N2,O2,Ar, He,unit);
}[/cpp]
and this for the Fortran:
[plain]Function pt_h_gas(p , t, y1, y2, y3, y4, y5, y6, y7,unit) bind(C)
use iso_c_binding
real(C_DOUBLE) :: pt_h_gas
real(C_FLOAT), value:: y1, y2, y3, y4, y5, y6, y7, unit
real(C_DOUBLE) :: p, t[/plain]
Christer
[cpp]extern "C"
#include "stdafx.h"
double enthalpy;
double p,t;
}[/cpp]
use iso_c_binding
Many thanks for your answers!
Well, I used cdecl but as I got more "desparate" I tested everything including stdcall so the code I sent was just one in many examples. (Actually the libaray/dll was created in CVF and I did not know if CVF was created with cdecl or stdcall)
Uppercase was was just an editing mistake; it was from me testing without alias when it did work with linking problem.
iso_c_binding was something new, thanks for the tip!
Butis thereany flag for C++ to stop adding the underscore prefix? (Maybe wrong forum butI can always try!)
Jugoslav_Dujic
Valued Contributor II
Quoting - Christer
I think not (I might be wrong though), but why does it bother you at all? Just go with the defaults. You can always use:
!DEC$ATTRIBUTES DECORATE, ALIAS: "whatever"
and the Fortran compiler will add whatever underscores and other decoration is required to match the calling convention.
I agree with Jugoslav that it makes more sense to let the compilers do their thing. Rather than use DECORATE I'd suggest the BIND(C,NAME="MixedCaseString") specification on the Fortran routine, as long as you aren't using STDCALL. This tells Fortran to create the same global name that the "companion" C compiler would use. You'll only get into trouble if you try to hard-code name decoration rules, especially if you move to a 64-bit platform where the decorations are different.
Christer
Thanks Steve and Jugoslav, I have learneda lotwhen reading your comments about mixed language!
The reason I was asking about avoiding prefix underscore was that my program is calling functions in an "official" dll/lib used for other programs. If I change the dll/lib (it is possible as I am the owner of that dll) I have to changethe other programs function calls and it will be a lot of work I do not have at the moment.
But with your tips Igot new ideas !
