29274 Discussions
How to cleanup unused use-only statements?
Jarek_T
I am working with a large Fortran code that is changing a lot. I am using Intel Fortran through Visual Studio on Windows. Occasionally I would like to do some code cleanup like for example finding all the places where I use use-only statement to declare that I will be calling a function which I am no longer calling. Is there a way to detect those?
I would also like to detect functions missing "implicit none" statements. I wonder if those can be done through a compiler, Visual Studio or some (free) 3rd party tools. I realize that I can write my own code to analyze my source-code but I would preferer to avoid it.
Ron_Green
extend -warn unused to include unused module procedures listed in USE ONLY is Feature Request CMPLRLLVM-61734
andrew_4619
The "use-only" thing is a question I raised a few years back. It would be nice "Warn-unused" applied but  it doesn't work or only works a 'little bit'.  Yes I think it would be a good feature if it worked and I will reiterate my feature request to Intel of long ago!
Sometimes I comment out the use-only and compare the errors list to the things I commented out but that is a bit tedious.
As to "implicit none" missing I also  once upon a time made a simple utility to find however since that time I have changed my opinion and don't use the 'belt and braces' approach. All my routines are in modules or sub-modules so I make do with the "implicit none(type, external)" in the module header only.
Ron_Green
The first question, dead 'use only' statements - that's a good question.  And I can see the need for that.  I posed this question to the team and will check for an existing Feature Request.  The DPD200256205 may help me find that.  Yes, found , it's new number CMPLRIL0-8879.   Doctor Fortran opened that request in 2014.  It was closed due to inactivity.  I'll reopen it for our IFX compiler.   One of our super smart Front-end developers has an interest in this feature and had this feedback:
"For #1, we already warn for things like unused variables, or uninitialized result values. So we theoretically have the ability to warn for unused “use-only” objects. In fact, it looks like nagfor already does it:
$ cat foo.f90
module m
contains
    subroutine sub()
        print *, "hi"
    end subroutine
end module
program p
    use m, only: sub
end program
$ nagfor foo.f90
NAG Fortran Compiler Release 7.2(Shin-Urayasu) Build 7203
Warning: foo.f90, line 11: SUB explicitly imported into P but not used
[NAG Fortran Compiler normal termination, 1 warning]
So if the customer has nagfor, they could use that. But it would be nice if we could do that too."
Then she asked me to open a new Feature Request for that.  I'll revive this feature request.
For the second ask - she suggested we open a Feature Request for a new option like "-warn implicit_typing". When set, all scopes which have implicit typing will get a warning for it.  I'll get that opened also. She thinks this is doable and not too complicated to implement.
Thanks for the suggestions.  These could be great additions to ifx!
Ron_Green
Ron_Green
and
add new feature and option so that all scopes which have implicit typing will get a warning Feature ID CMPLRLLVM-61735
