How to compile/link f90 programs?
s_alyahyai
I just installed Intel Fortran Compiler for 32-bit applications, Version 7.0 ,
I don't know how to start compilation and linking the .f programs.
I used the folloign comand:
ifc hello.f ?o hello
but it gave the following error message
program HELLO_WORLD
4 Lines Compiled
ld: No such file or directory
no executable program has been created!!!
what should I do?
TimP
ifc requires the basic linux development environment to have been installed (ld and certain libraries). Those may have been optional components in your linux installation.
jindalkshah
I am also running into the same problem. After installation i run ldconfig and it gives me error that some of the files (related to fortran compiler) are too small and hence not checked. And I still receive the error...ld no directory or file found. any help in this regard would be appreciated.
thanks
Jindal
Martyn_C_Intel
You might want to reinstall, if you have not already done so. Otherwise, the Intel compiler requires a compatible set of Linux tools, as described in the release notes. What versions of gcc, glibc, ld and the Linux kernel do you have, and which Linux distribution do they come from?
Martyn
