How to compilte with fpp
Sebastiano_P_
Dear all,
I'm trying to compile with fpp option in Intel Visual Studio 2005.
On the basis of the information contained in previous posts in this forum, I tried to setup the configuration properties. As you can see in the attached screenshot, I defined the Preprocessor Definitions /DPARALLEL, where PARALLEL is the fpp option in my code (see below):
#ifdef PARALLEL
 REQUEST = MPI_REQUEST_NULL
 !send data share with UP
#endif
When I compiled the code in Linux, I used this simple command line:
ifort -r8 -fpp -DPARALLEL *f90
Sebastiano
Arjen_Markus
That is the way to do it, but is that not what is happening? You did not include a question or a problem statement in your post.
Sebastiano_P_
Thanks for the fast reply.
I obtain "Compilation Aborted (code 1)" (in Windows, while in Linux everything works correctly)
Sebastiano_P_
This is a quick test that I did now:
PROGRAM main
IMPLICIT NONE
#ifdef PARALLEL
     WRITE(*,*) 'Hallo world'
#else
     WRITE(*,*) 'Ciao mondo'
#endif
STOP
END PROGRAM
Also in this case, the error is "Compilation Aborted (code 1)", thus I'm wondering whether the procedure in my first post is correct.
Arjen_Markus
Hm, I suspect it is the definition of the macro. I tried it with PARALLEL - no /D, [...] or = and it was all fine.
Sebastiano_P_
Can you please post a screenshot of your configuration setup?
Sebastiano_P_
No problem. I solved by writing PARALLEL - no /D in Preprocessor Definitions.
Thank you for the help.
Sebastiano
Arjen_Markus
Oops, I had already removed it. But instead of /D[=PARALLEL], my properties window showed PARALLEL.
If you have looked at the online help, then you will see something like your version, but that is simply alternative syntaxes:
/DPARALLEL defines a macro PARALLEL
/DPARALLEL=1 defines a macro with the precise value 1
The [...] is to indicate the enclosed part is optional.
It sounds to me as if you're getting an internal compiler error. Are there no other error messages? Would you be able to provide us with the source that is failing (and that of any modules or include files it uses)? A ZIP of the project would be best for us.
Sebastiano_P_
Dear Steve,
I solved by writing simply PARALLEL in Preprocessor Definitions.
Thank you,
Sebastiano
