29270 Discussions
How to copy a bitmap to the clipboard
michael_green
Hi All,
I would like to be able to copy an image that I have captured using BitBlt to the Windows clipboard. If I've got the image captured into a memory device context how do I relate that to the required second argument for CopyMemory, that is, the "pointer to the address of the block to copy"?
Many thanks for any help or insights.
Mike
onkelhotte
New Contributor II
Hi Mike,
if you are using a QuickWin Application, it is easy to copy a QuickWin Window into the clipboard. I can send you a subroutine that does that for you.
But I dont know how to copy a memory block into the clipboard. Im not sure if the clipboard has a unique address in memory.
Markus
Jugoslav_Dujic
Valued Contributor II
Should be as simple as:
IF (OpenClipboard(NULL)) THEN
hBmp = GetCurrentObject(hMemDC, OBJ_BITMAP)
hData = SetClipboardData(CF_BITMAP, hBmp)
bSt = CloseClipboard()
END IF
anthonyrichards
New Contributor III
This works for me: Assume that the bitmap is ixwidth pixels wideby iywidth pixels high and assume it has been created and selected into a device context with handle hMemDC and drawn on. hWnd and hWndDC are the handles to the window and tothe window'sdevice context.
use user32
use dfwin
use dfwinty
use dflib
Implicit none ! all undeclared variables should be defined as INTEGER(4)
integer(4) hWnd, hWndDC
! Bitmap stuff...
INTEGER::hBmp, iSizeImage, cClrBits, iSt, hmemBmBits, hClipboard, hBitmap, hOldBitmap, ixwidth, iywidth, hMemDC,hWndDC
INTEGER(1)::bmBits(*); POINTER(pbmBits, bmBits)
TYPE(T_BITMAPINFO)::BI; POINTER(pBI,BI)
TYPE(T_BITMAP):: Bmp
TYPE (T_RECT)rc
retint=getclientrect(hWnd,rc)
ixwidth=rc%right-rc%left
iywidth=rc%bottom-rc%top
hBitmap=CreateCompatibleBitmap(hWndDC,ixwidth,iywidth)
hOldBitmap=SelectObject(hMemDC, hBitmap)
! Somewhere in here is your code todraw on the device context hMemDC. If you have not created hMemDC, just change references to hMemDCin the following to hWndDC
!Get the color depth bits of the bitmap
cClrBits=GetDeviceCaps(hMemDC, BITSPIXEL)
iSizeImage=((ixwidth * cClrBits + 31) /8) * iywidth
!Allocate memory for BITMAPINFO structure. It consists of BITMAPINFOHEADER
!structure followed immediately in memory by array of color bits.
hmemBmBits = GlobalAlloc(GMEM_MOVEABLE+GMEM_DDESHARE, iSizeImage+SIZEOF(BI%bmiHeader))
pbmBits= GlobalLock(hmemBmBits)
pBI = pbmBits
!Fill in the BITMAPINFOHEADER.
BI%bmiHeader%biSize= SIZEOF(BI%bmiHeader)
BI%bmiHeader%biWidth = ixwidth
BI%bmiHeader%biHeight= iywidth
BI%bmiHeader%biPlanes= 1 !1 plane (e.g. icons have 2)
BI%bmiHeader%biBitCount= cClrBits !color depth
BI%bmiHeader%biCompression = BI_RGB !no compression
BI%bmiHeader%biSizeImage = iSizeImage
BI%bmiHeader%biXPelsPerMeter = 96*100/2.54+1
BI%bmiHeader%biYPelsPerMeter = 96*100/2.54+1
BI%bmiHeader%biClrImportant = 0
!Get the bitmap bits into BI. Actual bits start at this offset--v
iSt= GetDIBits(hMemDC, hBitmap, 0, iywidth, pbmBits+SIZEOF(BI%bmiHeader), pBI, DIB_RGB_COLORS)
!clean up, only if you have created a compatible bitmap in hMemDC
hBitmap=SelectObject(hMemDC, hOldBitmap)
retint=DeleteObject(hBitmap)
retint=DeleteDC(hMemDC)
hClipboard = OpenClipboard(hWnd)
retint= EmptyClipboard()
iSt= SetClipboardData(CF_DIB, hmemBmBits) !Copy the contents onto clipboard
iSt= CloseClipboard()!Clean up
iSt= GlobalUnlock(hmemBmBits)
iSt= GlobalFree(hmemBmBits)
michael_green
Thanks Guys for the help.
Everything is working fine except for one small problem: I can't get EmptyClipboard to work. Here's the code I'm using:
if(OpenClipboard(null))then
iret =EmptyClipboard()
hBmp = GetCurrentObject(hMemDC,OBJ_BITMAP)
hData = SetClipboardData(CF_BITMAP,hBmp)
iret = CloseClipboard()
end if
After a couple of uses the clipboard tells me I must clear it before I can add any more. I have also found that a VF example program (one of Norman Lawrence's) causes exactly the same behaviour. Is there some setting of the clipboard on my machine that I must adjust, or is there something I just don't understand?
With many thanks in advance,
Mike
anthonyrichards
New Contributor III
Try OpenClipBoard with a valid handle, not NULL?
