29651 Discussions
How to create Fortran array referencing SafeArrayAccessData
MWind2
New Contributor III
VBArray INOUT length known
integer(C_INTPTR_T) :: dptr
iRes=SafeArrayAccessData(VBArray,dptr)
dptr address is starting point of one dimensional c array of real{8}
I want to put it in a Fortran array so I can see it in debugger for one reason, but I want the Fortran array to reference the underlying data and not be a copy. Intention would be changes to data in Fortran array would be preserved in dptr array.
Steve_Lionel
Two errors. First, you omitted the size argument I specified to C_F_POINTER. Second, you treated the array as if it were zero-origin, but the array you get from C_F_POINTER is one-origin. (This could be finessed with pointer assignment redeclaring the bounds, but that seems unnecessary.)
I attach my modified df.f90. I didn't change anything else.
MWind2
New Contributor III
New dll for adding more dimensions with 2d working
Steve_Lionel
I'm glad to see that you sorted this out.
MWind2
New Contributor III
Here's general code tested in 2d and 3d. Thanks for help and previous example with strings.
