29627 Discussions
How to debug an executable that takes command line arguments?
OP1
New Contributor III
How can I debug a code which reads command arguments from the command line it is launched from? More specifically, how do I provide these arguments to the code when I am debugging from VS 2005? I am using IVF 10.1.
Thanks!
Olivier
lklawrie
In the project properties window, under configuration, debugging (I am using VS2008, hope it's similar for 2005), there is a place for command line arguments. Put your arguments there.
Linda
OP1
New Contributor III
Quoting - lklawrie
Linda
Aaaargh... That was so simple! I can't believethis escaped my attention... Dumb, dumber, dumberer... I am getting there slowly...
Thanks a lot Linda!
Olivier
