29657 Discussions
How to declare a global variable?
weichao
I tried to use a global variable PI in C and FORTRAN codes.
But, it didn't work. Anyone could help me? Thanks.
In C code:
extern float PI;
extern "C" float PI_N(float b)
return PI*b;
In FORTRAN code:
module mod
interface
real function PI_N(b)
!dec$ attributes C ::add
!dec$ attributes value :: b
real::b
end function PI_N
end interface
end module mod
program test1
use mod
implicit none
real::b,res,PI
common /PI/PI
PI=3.1416
b=5.0
res=PI_N(b)
print*,res
end program test1
weichao
I got it!
I should add "C" at the line whereI declared the global variable.
extern "C" float PI;
