29277 Discussions
Retrieving selected items in a list box
Intel_C_Intel
I'm struggling withmy firstlist box. I get the dialog box open (contains just one list box, multiple selection mode) andget it populated just fine.
But after returning from dlgmodal, everything appears selected, e.g.
j = 1
test = -1
DO WHILE (test .NE. 0)
retlog = DLGGET (dlg2, IDC_NAMES, TEMP, j)
test = J
j = j + 1
END DO
returns every item in the list, regardless of selection. Must be something simple I'm missing. In fact, after the last item of the list returns, test continues to increment forever, even beyond the max number of items (1000)in the list. Retlog is false after the last populated entry as it should be)
Please help!
TIA
Jugoslav_Dujic
Valued Contributor II
4th argument of DlgGet is always INTENT(in) -- i.e. unchanged -- so your test to zero will always fail. For retrieveal of selection, 3rd argument should be integer, (which is INTENT(out)); its output value is index of n-th selected item, where n is value of 4th argument. Thus:
j = 1
DO WHILE (iTemp .NE. 0)
IF (DlgGet (dlg2, IDC_NAMES, iTemp, j)) THEN
!j-th selected string is iTemp-th in the list:
retlog = DlgGet(Dlg2, IDC_NAMES, sItem, iTemp)
!Do something with sItem (string)
END IF
j = j + 1
END DO
Jugoslav
Intel_C_Intel
Thanks! Solved the problem for me. I was trying to follow the example in the docs and couldn't get it to work.
Neal
