29649 Discussions
How to declare pointers to subroutines?
rwg
Today I found some old code with pointers to subroutines. It looks like this:
[fxfortran]      PROGRAM TEST
INTEGER LOCEX
EXTERNAL DEFEX
EXTERNAL TESTEX
C Save Pointer to external subroutine
CALL EXTERNALCALL('SAVE',LOC(TESTEX))
C Get Pointer to external subroutine
CALL EXTERNALCALL('GET',LOCEX)
C If not associated take DEFEX
IF(LOCEX.EQ.0) LOCEX=LOC(DEFEX)
C CALL LOCEX IN EXTERALTOOL
CALL CALLEXTERNAL(%VAL(LOCEX))
END
SUBROUTINE CALLEXTERNAL(EXPROG)
C Call an external subroutine
EXTERNAL EXPROG
CALL EXPROG
END
SUBROUTINE EXTERNALCALL(OPT,LOCEX)
C Save pointer to an external subroutine or return pointer to subroutine
CHARACTER(*) OPT
INTEGER LOCEX
INTEGER LOCEXSAVE
SAVE LOCEXSAVE
DATA LOCEXSAVE /0/
IF(OPT.EQ.'GET') THEN
LOCEX=LOCEXSAVE
ELSEIF(OPT.EQ.'SAVE') THEN
LOCEXSAVE=LOCEX
ENDIF
END
SUBROUTINE DEFEX
WRITE(*,*) "DEFEX"
READ(*,*)
END
SUBROUTINE TESTEX
WRITE(*,*) "TESTEX"
READ(*,*)
END[/fxfortran]
This code runs fine but it compiles only without /warn:interfaces. My attempts to correct the declarations result in internal compiler errors. Does someone know how to correct the declarations?
mecej4
What you have done with the nonstandard extension functions %LOC and %VAL can be achieved with the procedure pointer feature of Fortran 2003. This feature is (newly) available in Intel Fortran, but many other compilers do not provide it yet.
Here is a simple example:
[fortran]PROGRAM PROC_PTR_EXAMPLE
  REAL :: R1
  INTEGER :: I1
  INTERFACE
    SUBROUTINE SUB(X)
      REAL, INTENT(IN) :: X
    END SUBROUTINE SUB
  END INTERFACE
  PROCEDURE(SUB), POINTER :: PTR_TO_SUB => NULL()              ! with explicit interface
  PROCEDURE(SUB), POINTER :: PTR_TO_SUB1 => NULL()             ! with explicit interface
  EXTERNAL :: SUB1, SUB2
  PTR_TO_SUB => SUB1
  CALL PTR_TO_SUB(1.0)
  PTR_TO_SUB1 => SUB2                           ! save pointer
  NULLIFY(PTR_TO_SUB)                           ! make PTR_TO_SUB not callable
  PTR_TO_SUB => PTR_TO_SUB1                     ! restore pointer
  CALL PTR_TO_SUB(2.0)
END PROGRAM PROC_PTR_EXAMPLE
subroutine SUB1(X)
  real, intent(in) :: X
  write(*,10)x
  return
  10 format(' SUB1 ',1pE15.5)
end subroutine SUB1
subroutine SUB2(X)
  write(*,10)x*5
  return
  10 format(' SUB2 ',1pE15.5)
end subroutine SUB2
[/fortran]
rwg
Even though I would prefer a solution for FORTRAN90/95 I also tried it with procedure pointes but all my attempts result in internal compiler errors.
Your solution also gives me an internal compiler error. When I remove line 13 and 16 (PTR_TO_SUB=>SUB1 and PTR_TO_SUB=>PTR_TO_SUB1) the error is gone.
I'm using Intel Visual Fortran 11.1.065 [IA-32]
I don't see an error with 11.1.065. Which compiler options are you using?
rwg
Here are my compiler options:
/nologo /debug:full /Od /gen-interfaces /debug-parameters:all /warn:declarations /warn:unused /warn:ignore_loc /warn:uncalled /warn:interfaces /iface:cvf /module:"c:/sw/wg/testprj_fortran" /object:"Debug\" /traceback /check:bounds /libs:static /threads /dbglibs /c
Ok - remove /iface:cvf and it works. Reported as issue DPD200158540.
rwg
I'm glad to hear that it was not again my stupidity. Thank you!
This has been fixed in our sources. I'm not exactly sure of the timing - the fix might be in Update 2 (out in a couple of weeks) but if not, Update 3.
