How to get around a NaN?
ferrad
New User
I have successfully found where our code is trying to access a NaN, using full checking. However, now I know it is there I will fix it later, so what I want to do is move around it to find the next error. So I put in the following code:
if(isnan(tables_pl(i))) then
tables_mlf(i,nzone,temp_loc) = 0.0
else
tables_mlf(i,nzone,temp_loc) = tables_pl(i)
endif
However, I still get a floating point exception trying to access the NaN, but now on the if statement. Why can't the isnan test just return a .true., execute the next line and carry on to the next problem?
Adrian
jim_dempsey
I use the following code. Please adapt to your requirements
JFP_CLASS = FP_CLASS(FPLEN(JTETH1))
SELECT CASE (JFP_CLASS)
CASE (0)
call DOSTOP('TOSSF21 FOR_K_FP_SNAN')
CASE(1)
call DOSTOP('TOSSF21 FOR_K_FP_QNAN')
CASE(2)
call DOSTOP('TOSSF21 FOR_K_FP_POS_INF')
CASE(3)
call DOSTOP('TOSSF21 FOR_K_FP_NEG_INF')
CASE(4)
! OK - FOR_K_FP_POS_NORM
CASE(5)
! OK - FOR_K_FP_NEG_NORM
CASE(6)
call DOSTOP('TOSSF21 FOR_K_FP_POS_DENORM')
CASE(7)
call DOSTOP('TOSSF21 FOR_K_FP_NEG_DENORM')
CASE(8)
! OK - FOR_K_FP_POS_ZERO
CASE(9)
! OK - FOR_K_FP_NEG_ZERO ? Saw this with 0. * 9.900990099009901E-003
! ? could have been -0. * 9.900990099009901E-003
CASE DEFAULT
call DOSTOP('TOSSF21 FOR_K_FP_unknown')
END SELECT
The subroutine DOSTOP is a routine I call in lieu of performing a STOP (which is too hard to perform tracebacks). When debugging I keep a breakpoint in the suvroutine DOSTOP and it makes for an easy bug detection.
! common routine to perform CALL DOSTOP()
SUBROUTINE DOSTOP(CVAR)
CHARACTER*(*) CVAR
! place break point here
WRITE(IOUERR,*) CVAR
STOP 'DOSTOP'
! If you wish to continue use debugger to...
! Set Next Statement here
RETURN
END SUBROUTINE DOSTOP
Jim Dempsey
ferrad
New User
Not sure when I would call this stuff. If I call it before my isnan test, I have no exception. If I call it after, the exception has already occurred.
What I really need is for the code to go on past this NaN exception. I thought that's what isnan() would do - Steve am I right?
Adrian
Intel_C_Intel
Hello
You couldtake out this code (with NaN) and compile it in a separate file without any runtime checking, that is, typically full optimization and the /nocheck option. The rest of you files are with full error checking /check:all and all the other useful traps that have been added recently (read documentation).
Lars Petter
ferrad
New User
Yes, I can do that, but it would be better if isnan() worked.
Adrian
jim_dempsey
You call this in place of isnan(YourVariableHere) with breakpoints inserted accordingly.
This can be used to catch both types of NaN as well as other odd values.
It is up to you to determine the appropriate action to take. You can make a function call out of this if you have many such places to test.
Cleaned up code follows
JFP_CLASS = FP_CLASS(YourVariableHere)
CASE(0) ! FOR_K_FP_SNAN
YourVariableHere = 0
CASE(1) ! FOR_K_FP_QNAN
CASE(2) ! FOR_K_FP_POS_INF
! do nothing
CASE(3) ! FOR_K_FP_NEG_INF
! do nothing
CASE(4) ! FOR_K_FP_POS_NORM
! do nothing
CASE(5) ! FOR_K_FP_NEG_NORM
! do nothing
CASE(6) ! FOR_K_FP_POS_DENORM
YourVariableHere = YourVariableHere ! try to normalize
CASE(7) ! FOR_K_FP_NEG_DENORM
CASE(8) ! FOR_K_FP_POS_ZERO
! do nothing
CASE(9) ! FOR_K_FP_NEG_ZERO
CASE DEFAULT
call DOSTOP('FOR_K_FP_unknown')
END SELECT
Jim Dempsey
ferrad
New User
I just tried that, but it still stops in the external routine with an exception on the line:
The external routine is compiled with:
ifort /nologo /c /iface:cvf /Zi /nocheck /dbglibs /Tfmlf_restart_dynamic1.for /define:INTEL9 /Qsave /Fomlf_restart_dynamic1.obj /fpconstant /real_size:64 /Zi /4R8 /nocheck /extend-source:132 /debug-parameters:all
Adrian
ferrad
New User
Nope that still fails on the line:
JFP_CLASS =
FP_CLASS(tables_pl(i))
when tables_pl(i) is a NaN
Same external routine is above, same compiler switches.
ferrad
New User
Jim,
Interesting observation: I have breakpoints set for cases 1 and 2 above. It stops for some NaN's in the correct place (case 1) and sets the value to zero, but for others it stops with the exception on the JFP_CLASS = FPCLASS(... line.
All NaN's have different bit patterns.
Adrian
Neither ISNAN nor FP_CLASS should trigger an error when a NaN is accessed. If you have an example where it does, please submit a test case to Intel Premier Support.
jim_dempsey
It may be that you have an invalid address (as opposed to the contents at the address is NaN).
Your test was for an element of an array.
Check:
1) see that the array was allocated (or pointer valid)
2) if the array name is passed into a subroutine (which is where the failure is) make sure the dummy argument is indeed the address of thearray you assume it is.
3) verify the index is valid.
4) verify the array type is indeed what you expect it to be (e.g. the subroutine where the failure is encountered expects REAL(8) but the caller is passing in REAL(4), or INTEGER(4), ...)
5) check the other unusual JFP_CLASS case statements
Jim
ferrad
New User
It is an array in a common block, and I can see its contents without any problemin the watch window.
n/a (common block var)
index is 69019 (array is sized larger than that).
It's a real*4 array.
The code works fine for the previous 69018 values of i.
See attached screen capture,
Adrian
ferrad
New User
Steve, I'm trying to reproduce this in a standalone program. I need to write out the bit patterns for these reals into some file, then read them in again into my standalone program. What format do I use write and read these bit patterns?
Adrian
ferrad
New User
Steve,
Never mind, I've reproduced it. I'll submit to Premier Support now.
Adrian
jim_dempsey
Is this a multi-threaded program?
Also, when you get the NaN set the display to Hex. This will help to determine if there is a bug in FP_CLASS. IEEE definition of NaN
Not A Number
The value NaN (Not a Number) is used to represent a value that does not represent a real number. NaN's are represented by a bit pattern with an exponent of all 1s and a non-zero fraction. There are two categories of NaN: QNaN (Quiet NaN) and SNaN (Signalling NaN).
A QNaN is a NaN with the most significant fraction bit set. QNaN's propagate freely through most arithmetic operations. These values pop out of an operation when the result is not mathematically defined.
An SNaN is a NaN with the most significant fraction bit clear. It is used to signal an exception when used in operations. SNaN's can be handy to assign to uninitialized variables to trap premature usage.
Semantically, QNaN's denote indeterminate operations, while SNaN's denote invalid operations.
Jim Dempsey
ferrad
New User
No, just a regular single threaded app. I have reproduced it on a small program and submitted it to premier support.
Adrian
FYI, the NaN causing this type of problem is:
data i1 /4287075194/
real*4 r1
equivalence (r1,i1)
if you're interested, I can send you the example.
jim_dempsey
Thanks for the statements. On my system the isnan test works as it should. See .JPG
Jim Dempsey
ferrad
New User
You have to compile the file with /Od /fpe:0 to see the problem - Premier support have reproduced it and are fixing it.
Adrian
jim_dempsey
First example (prior .JPG) had Floating-Point Exception Handling set to:
Produce NaN, signed infinities, and denormal results
This .JPG has Floating-Point Exception Handling set to:
Underflow gives 0.0; Abort on other IEE exceptions
Jim Dempsey
ferrad
New User
If you change the first access of the NaN to an FP_CLASS statement and compile with /Od /fpe:0, you will get the error I mention. Here is my code:
program nantest
implicit none
integer*4 i1
integer JFP_CLASS
real*4 r1
equivalence (r1,i1)
JFP_CLASS = FP_CLASS(r1)
end
Adrian
jim_dempsey
Adrian,
Here is a work around. Note the isnan works when exceptions enabled.
Jim Dempsey
