29642 Discussions
How to get around errors during linking a Windows DLL with code in SUBMODULEs using /IFACE:CVF?
FortranFan
This inquiry is an attempt to assist a team at work who currently encounter error(s) during linking a Windows DLL with a Fortran codebase that uses SUBMODULEs (due to my prior advice) and which also employs the /IFACE:CVF compiler option.
Unfortunately I don't have all the details and due to the sensitive nature of the work involving external customers and US DOE, I am not authorized to review any code besides a few API procedures which I am not allowed to refactor either.  Thus I am constrained in what I can do.
Based on the limited information the team shared with me verbally, I came up with the following reproducer:
  1. Say there is a module 'm' in a file 'm.f90' that defines some procedure interfaces, say a subroutine named 'SUB' and a function 'FUNC'
    module m
       interface
          module subroutine sub(a)
          !DIR$ ATTRIBUTES DECORATE, ALIAS : 'M_SUB' :: sub
          !DIR$ ATTRIBUTES DLLEXPORT :: sub
             integer, intent(inout) :: a
          end subroutine
          module function func(x) result(r)
          !DIR$ ATTRIBUTES DECORATE, ALIAS : 'M_FUNC' :: func
          !DIR$ ATTRIBUTES DLLEXPORT :: func
             integer, intent(in) :: x
             integer :: r
          end function
       end interface
    end module
  2. Say the subroutine 'SUB' is implemented in a SUBMODULE in a file named 'sub.f90'
    submodule(m) sub_sm
    contains
       module subroutine sub( a )
          a = func( a ) + 42
       end subroutine
    end submodule​
  3. Similarly the function 'FUNC' in a SUBMODULE in a file named 'func'
    submodule(m) func_sm
    contains
          integer :: r
          r = x + 1
       end function
    end submodule​
The requirements due to the project agreements among all the parties include:
  1. The target platform for the Windows DLL shall be IA-32,
  2. The use of the DLL among different parties imply the protocol for the external procedures shall be STDCALL, REFERENCE, and MIXED_STRING_LEN_ARG for character string length argument passing i.e., /IFACE:CVF
  3. There must be ALIASes for the API procedures but which are not based on `BIND(C)`.
The naïve reproducer above strives to include these 3 requirements.  Here is an illustration of the linker error(s) encountered with this reproducer:
C:\temp>ifort /c /standard-semantics /iface:cvf /Qm32 m.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on IA-32, Version 2021.7.0 Build 20220726_000000
Copyright (C) 1985-2022 Intel Corporation.  All rights reserved.
C:\temp>ifort /c /standard-semantics /iface:cvf /Qm32 sub.f90
C:\temp>ifort /c /standard-semantics /iface:cvf /Qm32 func.f90
C:\temp>link m.obj sub.obj func.obj /dll /out:m.dll
Microsoft (R) Incremental Linker Version 14.33.31630.0
Copyright (C) Microsoft Corporation.  All rights reserved.
func.obj : error LNK2005: _M already defined in sub.obj
   Creating library m.lib and object m.exp
LINK : warning LNK4217: symbol '_M_FUNC@4' defined in 'func.obj' is imported by 'sub.obj' in function '_M_SUB'
m.dll : fatal error LNK1169: one or more multiply defined symbols found
C:\temp>
 Now consider the same exact code built using /IFACE:default option:
C:\temp>ifort /c /standard-semantics /iface:default /Qm32 m.f90
C:\temp>ifort /c /standard-semantics /iface:default /Qm32 sub.f90
C:\temp>ifort /c /standard-semantics /iface:default /Qm32 func.f90
LINK : warning LNK4217: symbol '_M_FUNC' defined in 'func.obj' is imported by 'sub.obj' in function '_M_SUB'
C:\temp>
But for the LNK4217 warning, the Microsoft linker succeeding in creating the DLL.  Now consider a trivial caller of this DLL in a file named 'p.f90':
   use m, only : sub
   integer :: n
   n = 0
   call sub( n )
   print *, n
end
 Here is the program response consuming the above DLL:
C:\temp>ifort p.f90 m.lib /standard-semantics
-out:p.exe
-subsystem:console
p.obj
m.lib
C:\temp>p.exe
 43
C:\temp>
Thus code is correct enough to work with /IFACE:default setting, but the linker fails when the code is processed using /IFACE:CVF option.
The questions I am grappling with include: 1)  why does the linker throw errors with /IFACE:CVF and 2) how can this team get around the linker error while satisfying their program requirements.  My hunch is the answer to 1) is a bug in Intel Fortran compiler: therefore I have submitted a support request with Intel Online Support Center.  And I have asked about 2).
Does anyone have any suggestions or feedback on why the linker error(s) and how to get around them?
Thank you,
mfinnis
New Contributor III
Do you get what you want by using /IFACE:DEFAULT and putting CVF in the !DIR$ ATTRIBUTES statements (eg !DIR$ ATTRIBUTES CVF, DECORATE, ALIAS : 'M_SUB' :: sub) ? It seems to compile and link ok with ifort 19.1.2.254 (though the function names in the warning are different)
1>Compiling with Intel(R) Visual Fortran Compiler 19.1.2.254 [IA-32]...
1>m.f90
1>func.f90
1>sub.f90
1>Linking...
1>Creating library G:\Sandbox\Scratch\temps01\Console1\Dll1\Debug\Dll1.lib and object G:\Sandbox\Scratch\temps01\Console1\Dll1\Debug\Dll1.exp
1>sub.obj : warning LNK4217: locally defined symbol _M_mp_M_FUNC@4 imported in function _M_mp_M_SUB
FortranFan
@mfinnis ,
Thank you very much for your reply and your looking into this, greatly appreciated.  I have forwarded the link to this thread and your reply to this team.  They tell me they are currently constrained to apply the /IFACE:CVF to the Fortran MODULE files also due to several factors involving external customers and a custom build system from a 3rd party simulation vendor.  And with that /IFACE:CVF option, the linker error persists unfortunately.
Steve_Lionel
This is indeed a compiler bug, but there is a workaround. (In fact, the workaround is preferable to using /iface).
Compare the symbol dump from submodule M compiled with /iface:cvf
000 00000000 SECT1  notype       Static       | .text
    Section length   30, #relocs    1, #linenums    0, checksum        0
002 00000000 SECT1  notype ()    External     | _M@SUB_SM.@0
003 00000000 SECT1  notype ()    External     | _M
004 00000010 SECT1  notype ()    External     | _M_SUB@4
005 00000010 SECT1  notype ()    External     | _M_SUB
006 00000000 UNDEF  notype       External     | __imp__M_FUNC@4
007 00000000 SECT2  notype       Static       | .drectve
    Section length   FD, #relocs    0, #linenums    0, checksum        0
009 00000001 ABS    notype       Static       | @feat.00
and without:
003 00000010 SECT1  notype ()    External     | _M_SUB
004 00000000 UNDEF  notype       External     | __imp__M_FUNC
005 00000000 SECT2  notype       Static       | .drectve
    Section length   C9, #relocs    0, #linenums    0, checksum        0
007 00000001 ABS    notype       Static       | @feat.00
Notice that with /iface:CVF, there is an extraneous symbol _M defined - this should not be there. This symbol is properly created when module M is compiled (there is a version with and without STDCALL decoration), but it should not be there for the submodule.
The workaround? Instead of using /iface:cvf, add CVF to the ATTRIBUTES directive for the exported symbols. You'll need to do this in both the module and the submodule. For example:
module m
   interface
      !DIR$ ATTRIBUTES DLLEXPORT, CVF :: sub
      end subroutine
      !DIR$ ATTRIBUTES DLLEXPORT, CVF :: func
         integer :: r
      end function
   end interface
end module
submodule(m) sub_sm
contains
      a = func( a ) + 42
   end subroutine
end submodule
contains
      integer :: r
      r = x + 1
   end function
end submodule
If we do that and compile sub.f90 without /iface, we get:
003 00000010 SECT1  notype ()    External     | _M_mp_M_SUB@4
004 00000010 SECT1  notype ()    External     | _M_mp_M_SUB
005 00000000 UNDEF  notype       External     | __imp__M_mp_M_FUNC@4
006 00000000 SECT2  notype       Static       | .drectve
    Section length  111, #relocs    0, #linenums    0, checksum        0
008 00000001 ABS    notype       Static       | @feat.00
Putting it all together:
D:\Projects>ifort /c /standard-semantics m.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on IA-32, Version 2021.7.1 Build 20221019_000000
D:\Projects>ifort /c /standard-semantics sub.f90
D:\Projects>ifort /c /standard-semantics func.f90
D:\Projects>link m.obj sub.obj func.obj /dll /out:m.dll
LINK : warning LNK4217: symbol '_M_mp_M_FUNC@4' defined in 'func.obj' is imported by 'sub.obj' in function '_M_mp_M_SUB'
In general, avoid using command line options such as /iface and /names - use ATTRIBUTES directives if you need to.
By the way, that link warning can be ignored - it is telling you that you asked a symbol to be DLLIMPORTed, but it is defined in that DLL. This happens because the interface for func specifies DLLEXPORT, which turns into a DLLIMPORT when the module is used (implicitly by the submodules.)
FortranFan
Thank you Steve, as I mentioned in my previous comment the team in question has the link to this thread plus I have forwarded to them your post.
Barbara_P_Intel
AND, @FortranFan already filed a bug on this. Thank you!
FortranFan
Thanks @Barbara_P_Intel , hopefully the Intel Fortran team will agree it is a bug and be able to provide a fix in IFORT in a future release.
