How to get filesize?
onkelhotte
New Contributor II
Hi there,
I need to know the size of a file. I cant use Win32 for this because the code needs to run on windows and vms. SoI need a fortran specific way...
Thanks in advance,
Markus
The only way that would work across those two systems is to open the file, read all the records and sum the size. If it is a formatted file and you don't want to count record separators (Windows), then something like this would work (I think)
SIZE=0
DO
READ (1,'(Q)',IOSTAT=IOS) RSIZE
IF (IOS /= 0) EXIT
SIZE = SIZE + RSIZE
END DO
Q is an extension that causes the number of unread bytes remaining in the record to be assigned to the next variable in the I/O list. It is supported by DEC/Compaq Fortran on VMS and by Intel Fortran.
If it is an unformatted file, this is harder.
An alternative is to write a utility routine to get the file size and use conditional compilation in that routine to use an OS-specific method.
