Sometimes when a program I am debugging is aborted, it leaves the console window behind.
I can open it, and minimize and scroll it, but I can't close it, or putting anything into it.
A Ctl-C has no effect.
The only way to get rid of it is to do a reboot, otherwise it hangs around forever.
Is there any another way to close it down?
Does anyone know why this would happen?
I have found that Process Explorer from www.sysinternals.com is better than TaskManager at identifying running processes (along with memory Working Set, I/Oetc) and I have been able to find and "kill" rogue programs when that has happened to me.
Les
Please view the thread dated February 19, 2010 titled: '"Stop Debugging" stops debugging but does not terminate and close debug execution window.'
Likely it is the same issue caused byWindows Automatic Update KB978037.
Les
