29487 Discussions
How to handle WM_CLOSE signal or event?
mostlyAtNight
Hello All,
I'm having some issues with a QuickWin application I'm working with.
When the window is closed using the x in the top right corner, the window closes, but the process remains active consuming CPU cycles.
I have tried using SIGNALQQ to capture the signal generated by closing the window but none of the following signals are matched:
SIG$INT
SIG$ABORT
SIG$ILL
SIG$SEGV
SIG$TERM
Is there a way of catching a signal generated when the window is closed so I can close the application down properly?
Any help would be much appreciated.
Kind regards,
Pete
Paul_Curtis
Valued Contributor I
Quoting - mostlyAtNight
I'm reasonably sure the message generated by clicking the x in the top right hand corner will be a WM_CLOSE message - any idea how to trap that in FORTRAN?
Yes, write your own proc for your Windows program and don't use quickwin.
onkelhotte
New Contributor II
I have seen this behaviour from time to time at my projects myself. The process stays in memory and allocates more and more RAM.
But I cannot reproduce or explain it.
Markus
anthonyrichards
New Contributor III
Quoting - onkelhotte
Markus
Look for the application SPYXX.EXE, which is usually installed along with Microsoft Visual Studio/Developer Studio and can be found in directory such as /program files/microsoft visual studio/common/tools/. This free application allows you to 'find' a window and start logging messages sent to it by the system, so you can follow what happens when you issue the WM_CLOSE message, or any other message.
mostlyAtNight
Quoting - anthonyrichards
Hi there,
Thanks for your response, I tried using this utility but each time I selected the main window of my program to try and recieve messages I keep getting the messge:
Spy++ has encountered a problem in the message hook. To prevent hanging the system, the hook has been disabled.....
Pete
Paul_Curtis
mostlyAtNight
Quoting - Paul Curtis
Hi Paul,
Thanks for your advice, I think this will be the route we'll be taking.
Pete
