How to inspect which flags are used
Karl_Yngve_L_
I am working on a Makefile where I am trying to find which flags to use. The current list of flags is (for some historical reason):
-r8 -fpe0 -g -debug all -traceback -fp-model source -warn all -warn unused -check all,noarg_temp_created
From searching, I believe this may be reduced to
-r8 -fpe0 -g -traceback -fp-model source -warn all -check all,noarg_temp_created
However, I was thinking that there might be an option that would list the options that were passed to `ifort`.
If you generate a listing file (-list), all of the flags used will be shown at the end.
Karl_Yngve_L_
Thanks, Steve! That works perfectly!
Matt_Thompson
Indeed! I never knew about this functionality. I think I might try and get a script using this for when I'm debugging a code and trying to clean up the flags.
Steve, is there any place in the Docs or on the Intel site that can help decipher some of the more obscure bits of the listing, e.g.,
       -fp_modbits nofp_contract             -fp_modbits nono_fp_contract
I figure most are only useful to your engineers, and for my purposes a "no-diff" means I got the same flags, I'm guessing.
Lorri_M_Intel
OK, this is one of our internal secrets, but "fp_modbits" is an extended list of fp-model bits, and yes, you're right, it's only interesting internally.
We'll look at fixing the output so that it says "fp_model" instead of "fp_modbits", to avoid the confusion.
        thanks --
                         --Lorri
Adel_S_
