29277 Discussions
How to judge a pointer's target has been deallocated?
Zhanghong_T_
Hi all,
We often use associated to judge if a pointer is null or not. But when the target of a pointer has been deallocated, the function associated can't work. Can anyone tell me how to judge it?
Zhanghong Tang
Anexample:
type(test), pointer:: test1, test2
allocate(test1)
test2=>test1
if(associated(test2))then
write(*,*)'associated'
else
write(*,*)'not associated'
endif
deallocate(test1)
! How to judge the target of test2 has been deallocated?????
else
endif
Zhanghong_T_
Ican't use the following code:
if(associated(test2, tes1))then
Because in real work I don't know test2's target is test1.
Jugoslav_Dujic
Valued Contributor II
You can't. Quote from Fortran Standard (2003 draft, but it's the same in F95):
16.4.2.1.3 Events that cause the association status of pointers to become undefined
The association status of a pointer becomes undefined when
25
(1) The pointer is pointer-assigned to a target that has an undefined association status,
(2) The target of the pointer is deallocated other than through the pointer
And Note 16.13:
...the target will cease to exist, leaving the pointer "dangling". This standard considers such pointers to have an undefined association status. They are neither associated nor disassociated. They shall not be used again in the program until their status has been reestablished. There is no requirement on a processor to be able to detect when a pointer target ceases to exist.
I know it doesn't help much, but you will probably have to redesign the program so that it doesn't happen.
Jugoslav
