29487 Discussions
How to make the console output lines scrolling
reidar
New User
I have a console application that does nothing but math operations.
To inform the user about the progress,  it prints messages to the screen like:
Step 1 completed…
Step 2 completed… etc
aso…
Instead I want the program to reprint or scroll on a single line by omitting the line feed.
In former days this could be  easily arranged with the statements:
WRITE(IDO,911)N
911     FORMAT('+'T5,'Step',I3,' Completed…')
But with IVF this does not work….
Do anybody have a clue how  a “scroll” function could be arranged?
Nikitopoulos__Theodo
You can try to use the carriagecontrol ='fortran' and the + character.  You can find an example in an older post:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/277417
Arjen_Markus
This is not so much a problem of Intel Fortran as a change in the behaviour of consoles in general in comparison with the old days.
A simple way to solve this - no guarantee though - is to use code like the small program below:
! noscroll.f90 --
!     Can we prevent scrolling?
program noscroll
    implicit none
    integer :: i
    do i = 1,10
        write(*,'(i4,a1)', advance = 'no') i, achar(13)
    enddo
endprogram noscroll
The "advance='no'" option makes sure no carriage return line feed is emitted, causing the console to start a new line and the achar(13) character is used to make the console "cursor" go back. The net effect: you write to the start of the same line with each iteration.
jimdempseyatthecove
You can also call a C Runtime Library routine to emit a character or null terminated string.
Jim Dempsey
reidar
New User
Thank you all for help.
The "advance=no" option seems to suppress both the LF and the position T5, thus produces an endless line........
So far I found the simplest solution was to open a user window with option "carriagecontrol='fortran' ".
Arjen_Markus
Hm, odd, I adjusted the write statement in the program I posted to:
        write(*,'(t5,a1,i4,a1)', advance = 'no') '!', i, achar(13)
and got:
    !  10
on the screen. Si in my case the T5 edit is working fine. "advance='no'" does suppress the carriage return AND the line feed. Which is why the write statement explicitly include writing the carriage return.
Using the carriagereturn option is definitely the easiest fix, but note that it is an Intel Fortran extension, whereas the above is standard Fortran ;).
reidar
New User
Ok, in my test I overlooked achar(13) in the output list, sorry. I tested once more, also by directly implementing the "write" statement from your example. However, it did not produce any output but from the "PRINT" statement.    A list of my program is shown below.  There must be something else which is different..
! The program is invoked from a dialogue in a Win32 program or from a command prompt
   program TVSimulation
    USE TVA_CalcControl
    implicit none
    ! Variables
    INTEGER IDUM,ISTAT,i
    IUNI=401                ! defined in TVA_CalcControl
!    open(file='user', unit=IUNI,carriagecontrol='FORTRAN')  ! This works
!    open(file='user', unit=IUNI)                            ! ... neither
!    print *, '************  START TVSIM  ************'
do i = 1,10
!    write(IUNI,'(T5,i4,a1)', advance = 'no') i, achar(13)
    enddo
    pause
    call TVSim(1,ISTAT)
    print *, 'PRESS RETURN TO EXCIT AND CLOSE WINDOW'
    READ(*,*)
    end program TVSimulation
IanH
It may depend on ifort version, but try Arjen's method with a FLUSH statement on the console unit.
program noscroll_with_flush
  use, intrinsic :: iso_fortran_env, only: output_unit
  use ifport, only: sleepqq
  implicit none
  integer :: i
  do i = 1,99
    write(*,'(i2,a1)', advance = 'no') i, achar(13)
    flush(output_unit)        ! <-----------
    ! Slow down so we can see output.
    call sleepqq(100)
  end do
end program noscroll_with_flush
Recent Windows 10 includes a much enhanced console subsystem, that can basically emulate a terminal (if you are running Windows Subsytem for Linux, it is a terminal).  You can have all sorts of fun with it.
program noscroll_deluxe
  use ifwin, only:  &
      handle,  &
      std_output_handle,  &
      invalid_handle_value,  &
      getstdhandle,  &
      bool,  &
      dword,  &
      setconsolemode
  implicit none
  integer(handle) :: stdout_handle
  integer(bool) :: rc
  integer(dword) :: mode
  character(2) :: col
  integer :: i
  ! Not defined in 17.0.1's kernel32 module.
  integer(dword), parameter ::  &
      enable_virtual_terminal_processing = int(z'0004',dword)
  interface
    ! The description of this in ifort's kernel32.f90 is a bit wonky.
    function GetConsoleMode(hConsoleHandle, lpMode)  &
        bind(c, name='GetConsoleMode')
      use ifwinty
      integer(handle), value :: hConsoleHandle
      integer(dword), intent(out) :: lpMode
      !DEC$ ATTRIBUTES STDCALL :: GetConsoleMode
      integer(bool) :: GetConsoleMode
    end function GetConsoleMode
  end interface
  stdout_handle = getstdhandle(std_output_handle)
  if (stdout_handle == invalid_handle_value)  &
      error stop 'no stdout!'
  rc = getconsolemode(stdout_handle, mode)
  if (rc == 0)  &
      error stop 'stdout not a console!'
  mode = ior(mode, enable_virtual_terminal_processing)
  rc = setconsolemode(stdout_handle, mode)
  if (rc == 0)  &
      error stop 'windows version too old :('
  print "()"
  do i = 1,99
      write (col, '(i2)') mod(i,8) + 30
      print "(a,i2)",  char(27) // '[1F' // char(27) // '[' // col // 'm', i
      call sleepqq(100)
  end do
  print "(a)", char(27) // '[0m'
end program noscroll_deluxe
See https://msdn.microsoft.com/en-us/library/windows/desktop/mt638032(v=vs.85).aspx for information on the support escape codes.
Arjen_Markus
I was curious about the PAUSE statement in your sample program, but it still works indeed :). The problem for which Ian proposes a FLUSH statement is simple: at the end of the do-loop the write position is again at the start of the line that holds the last output ("    ! 10"). So the message from PAUSE overwrites that.
An alternative could be:
program noscroll
	    implicit none
	    integer ::
	    do i = 1,10
	    enddo
            write(*,*) '' ! Force the output cursor to the next line
endprogram noscroll
reidar
New User
Thank you all for interesting suggestions!
Well, I checked my latest purchased textbook about Fortran, "Fortran 90 Explained" by M. Metcalf and J. Reid.  There is a chapter about Fortran carriage control which states: "The first character on each output record (eg to the lineprinter) must be of default kind. It is not printed but interpreted as a carriage control character...The carriage control characters defined by the standard are: b - to start a new line, + - to remain on the same line (overprint), 0 - to skip a line, 1 - to advance to the beginning of next page."  But of course the standard may have been changed..
With IVF you have to open a device with the carriagecontol="fortran" which is IVF specific extension to make the overprint work..
Arjen_Markus
Well, there is slightly more to it than that: the console has to cooperate. Just think of all those programming languages that do not use this Fortran (or perhaps FORTRAN) feature. C for instance requires you to explicitly specify a new line to go the next line in the console and any character will simply be printed. Apparently the CARRIAGECONTROL keyword arranges for the output to obey the conventions used by FORTRAN in the old days.
Arjen_Markus
