Hi all,
Upon detecting an error, a program can be terminated with something
like
if(error) stop 1 ! normal termination
if(error) error stop 1 ! error termination, f2008
if(error) call abort ! nonstandard
With gfortran, the last option produces a backtrace, while the first
two do not (see also
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=52594 )
My question is whether there is a way to obtain a backtrace with ifort
with anyone of these program termination, possibly by choosing the
proper compiler options.
Thank you, regards,
Marco Restelli
DId you build with -traceback or -g? What happens then if you call abort (gcc or libgfortran implementation of the standard C function) or call sys_abort() directly? These would require iso_c_interop as they are plain C function calls, no underscore decoration.
Tim, yes, I tried and I didn't see the backtrace, but after double
checking I see a rather erratic behaviour. Consider the attached code:
on one machine with ifort Version 14.0 Build 20130728 to see the
backtrace I have to include the line `` write(*,*) "Test" '':
$ ifort -g -traceback test.f90 -o test
$ ifort -g -traceback test.f90 -o test # without line 8
$ ./test
abort:
$ ifort -g -traceback test.f90 -o test # with line 8
$ ./test
Test
Test
Test
Test
Test
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
test 0000000000471289 Unknown Unknown Unknown
test 000000000046FC00 Unknown Unknown Unknown
test 0000000000449A12 Unknown Unknown Unknown
test 0000000000436763 Unknown Unknown Unknown
test 000000000040359B Unknown Unknown Unknown
libpthread.so.0 00007F762767EBF0 Unknown Unknown Unknown
test 000000000047226E Unknown Unknown Unknown
test 0000000000402F9A Unknown Unknown Unknown
test 0000000000402E8D m_mp_f_ 10 test.f90
test 0000000000402EB2 m_mp_f_ 12 test.f90
test 0000000000402EF2 MAIN__ 19 test.f90
test 0000000000402DE6 Unknown Unknown Unknown
libc.so.6 00007F76270E660D Unknown Unknown Unknown
test 0000000000402CB9 Unknown Unknown Unknown
On another machine with ifort Version 13.1.2.183 Build 20130514 I
can't see any backtrace, no matter what.
Could you reproduce this behaviour, or is it somehow related to my
settings?
I still have not done the test with sys_abort() .
Thank you, Marco
module m
implicit none
contains
recursive function f(x) result(y)
real, intent(in) :: x
real :: y
write(*,*) "Test" ! add this line to see the backtrace
if(x.gt.10.0) &
call abort
y = f(2.0*x)
end function f
end module m
program test
use m
implicit none
write(*,*) f(1.0)
end program test
Marco, I can reproduce your results. I don't know at this time why the traceback is not produced when using the ifort version 13.1.3.192. There may have been a previous report of this that is fixed in the ifort 14.0 compiler. I can check about that and post again after I know more.
Kevin, thank you for checking. So, apart from specific issues with some compiler version, am I correct assuming that:
call abort + -g -traceback -> backtrace
stop / error stop -> no backtrace
Thank you, Marco
