Comunicados
29283 Discussões
How to optimize this codes to make it as fast as possible in Fortran?
Xia__Brian
Principiante
5.186 Visualizações
Hi, everyone!  I am writing a sort of scientific computing program which contains a part looks as follows:
! derived type
type, public :: block_arrayRR_type
	real(8), allocatable :: matA(:,:)
end type
type(block_arrayRR_type), allocatable :: Dx(:), Dy(:)
! temporary array
real(8)		invM_R(8,maxNp)	! maxNp is the biggest vector size
real(8) 	invM_Sx_f(8)
real(8) 	invM_Sy_f(8)
! main loop
do i = 1, ELE_num
	! fetch sub vector and matrix size Np
	associate( Np => ELE_Ept_num(i) )
	do Ept = 1, Np
		invM_Sx_f = 0.0
		invM_Sy_f = 0.0
		! fetch sub vector index, pt varis with Ept in unit stride
		! such as Ept=1,2,3..., pt=10,11,12,...,
		associate( pt => ELE_EP2P(Ept,i) )
		do Ept2 = 1, Np
			! fetch sub vector index, pt2 varis with Ept2 in unit stride
			associate( pt2 => ELE_EP2P(Ept2,i) )
			invM_Sx_f(1) = invM_Sx_f(1) + Dx(i)%matA(Ept2,Ept)*Pt_f(1,Pt2)
			invM_Sx_f(3) = invM_Sx_f(3) + Dx(i)%matA(Ept2,Ept)*Pt_f(3,Pt2)
			invM_Sx_f(5) = invM_Sx_f(5) + Dx(i)%matA(Ept2,Ept)*Pt_f(5,Pt2)
			invM_Sx_f(6) = invM_Sx_f(6) + Dx(i)%matA(Ept2,Ept)*Pt_f(6,Pt2)
			invM_Sx_f(7) = invM_Sx_f(7) + Dx(i)%matA(Ept2,Ept)*Pt_f(7,Pt2)
			invM_Sx_f(8) = invM_Sx_f(8) + Dx(i)%matA(Ept2,Ept)*Pt_f(8,pt2)
			invM_Sy_f(2) = invM_Sy_f(2) + Dy(i)%matA(Ept2,EPt)*Pt_f(2,pt2)
			invM_Sy_f(4) = invM_Sy_f(4) + Dy(i)%matA(Ept2,EPt)*Pt_f(4,pt2)
			invM_Sy_f(5) = invM_Sy_f(5) + Dy(i)%matA(Ept2,EPt)*Pt_f(5,pt2)
			invM_Sy_f(6) = invM_Sy_f(6) + Dy(i)%matA(Ept2,EPt)*Pt_f(6,pt2)
			invM_Sy_f(7) = invM_Sy_f(7) + Dy(i)%matA(Ept2,EPt)*Pt_f(7,pt2)
			invM_Sy_f(8) = invM_Sy_f(8) + Dy(i)%matA(Ept2,EPt)*Pt_f(8,pt2)
			end associate
		end do ! Ept2
		Pt_df(1,pt) = RK_a*Pt_df(1,pt) + dt*( invM_R(1,Ept)-ea(1,1)*invM_Sx_f(1))
		Pt_df(2,pt) = RK_a*Pt_df(2,pt) + dt*( invM_R(2,Ept)-ea(2,2)*invM_Sy_f(2))
		Pt_df(3,pt) = RK_a*Pt_df(3,pt) + dt*( invM_R(3,Ept)-ea(1,3)*invM_Sx_f(3))
		Pt_df(4,pt) = RK_a*Pt_df(4,pt) + dt*( invM_R(4,Ept)-ea(2,4)*invM_Sy_f(4))
		Pt_df(5,pt) = RK_a*Pt_df(5,pt) + dt*( invM_R(5,Ept)-ea(1,5)*invM_Sx_f(5)&
														   -ea(2,5)*invM_Sy_f(5))
		Pt_df(6,pt) = RK_a*Pt_df(6,pt) + dt*( invM_R(6,Ept)-ea(1,6)*invM_Sx_f(6)&
														   -ea(2,6)*invM_Sy_f(6))
		Pt_df(7,pt) = RK_a*Pt_df(7,pt) + dt*( invM_R(7,Ept)-ea(1,7)*invM_Sx_f(7)&
														   -ea(2,7)*invM_Sy_f(7))
		Pt_df(8,pt) = RK_a*Pt_df(8,pt) + dt*( invM_R(8,Ept)-ea(1,8)*invM_Sx_f(8)&
														   -ea(2,8)*invM_Sy_f(8))
		end associate
	end do! Ept
	end associate
end do! i
All variables appear in the code above are intrinsic array or scalar data type (except Dx and Dy).
It is the fastest version I can get so far, but the speed is still not satisfactory yet.
Can anyone provide help? Thanks a lot!
20 Respostas
JohnNichols
Colaborador valorado III
5.146 Visualizações
Patiently await the response from Jim or Steve or mecej4.
I would suggest that repeating the same operation is not necessarily optimal.
I use multiple threads, but your problem is small in terms of steps to thread.
Once you start run timing profiles to see if it actually helps.
Good luck.
JohnNichols
5.146 Visualizações
Forgot Fortran Fan - it all depends who is watching on a Sunday afternoon when there is no football.
Xia__Brian
Principiante
5.137 Visualizações
Hello, everyone! I am the oringinal poster. Thanks for all the responses!
I am freshman in forum and I am so careless that I post this thread early before I finish writing.
I forgot to provide some additional info which may help you to better understand the situation :
The core of the code is perform matrix multiplication(  Dx * Pt_f , Dy * Pt_f )  and update Pt_df.
It looks a bit weird and lengthy because of the following reasons:
1.   Not all 'alpha' in Pt_f (alpha,pt) needs to evaluate because some ea(:,alpha) equals zero exactly.
So I have already omitted them and manually unrolled the alpha loop, as can be seen in the above codes.
It makes the code lengthy but also makes it faster. I guess manually unrolling loop helps compiler to vectorize the codes.
2.   For different element ' i ' ,  the matrix and vector size 'Np' may be different.
To reduce memory consumption, I pack the vectors into a long one( such as Pt_f(alpha, pt) )
and arrange the matrices to structured type( such as Dx(i)%maxA(Np,Np) ).
As you see ELE_EP2P(Ept,i) is used to fetch the sub vector index 'pt'.
The matrix and vetor size Np ranges about 5~200 depending on specific application.
The main loop count ELE_num is a large number.
I have already tried many modification to this code, but the above seems the fastest one I can get.
By VTune profiling, I found the percentage of vectorization Ops is low(<20%)  and FLOPS speed is also not ideal.
I do believe there is definitly much better way to perform this task because it is indeed matrix multiplication!!!!
I have tried the intrinsic function 'matmul'  and MKL blas subroutine 'gemv', but I can not get performance gains.
Can anyone provide some useful suggestions??
jimdempseyatthecove
Colaborador honorário III
5.089 Visualizações
1) I would suggest you change the Ept2 loop
from constructing two non-unit stride temporary arrays (two 8-element arrays containing 6 values not compacted)
to constructing three four-element contiguous arrays
2) Prior to the DO i loop construct three four-element copies of the ea array in the selection order as used after the Ept2 looop
These two changes should permit better AVX2 optimization.
Jim Dempsey
JohnNichols
5.057 Visualizações
Jim  Is there no way to break up the operations and use more threads?
Xia__Brian
Principiante
5.035 Visualizações
Hi Jim
I am not sure whether I get you ideas exactly but I try the following version:
! derived type
end type
! temporary array
real(8) 	invM_Sx_f(4)
real(8) 	invM_Sy_f(4)
real(8) 	invM_S1_f(4)
! main loop
do i = 1, ELE_num
	do Ept = 1, Np
		invM_Sx_f = 0.0
		invM_Sy_f = 0.0
		invM_S1_f = 0.0
		do Ept2 = 1, Np
			invM_S1_f(1) = invM_S1_f(1) + Dx(i)%matA(Ept2,Ept)*Pt_f(1,Pt2)
			invM_S1_f(2) = invM_S1_f(2) + Dy(i)%matA(Ept2,EPt)*Pt_f(2,pt2)
			invM_S1_f(3) = invM_S1_f(3) + Dx(i)%matA(Ept2,Ept)*Pt_f(3,Pt2)
			invM_S1_f(4) = invM_S1_f(4) + Dy(i)%matA(Ept2,EPt)*Pt_f(4,pt2)
			invM_Sx_f(1) = invM_Sx_f(1) + Dx(i)%matA(Ept2,Ept)*Pt_f(5,Pt2)
			invM_Sx_f(2) = invM_Sx_f(2) + Dx(i)%matA(Ept2,Ept)*Pt_f(6,Pt2)
			invM_Sx_f(3) = invM_Sx_f(3) + Dx(i)%matA(Ept2,Ept)*Pt_f(7,Pt2)
			invM_Sx_f(4) = invM_Sx_f(4) + Dx(i)%matA(Ept2,Ept)*Pt_f(8,pt2)
			invM_Sy_f(1) = invM_Sy_f(1) + Dy(i)%matA(Ept2,EPt)*Pt_f(5,pt2)
			invM_Sy_f(2) = invM_Sy_f(2) + Dy(i)%matA(Ept2,EPt)*Pt_f(6,pt2)
			invM_Sy_f(3) = invM_Sy_f(3) + Dy(i)%matA(Ept2,EPt)*Pt_f(7,pt2)
			invM_Sy_f(4) = invM_Sy_f(4) + Dy(i)%matA(Ept2,EPt)*Pt_f(8,pt2)
			end associate
		end do ! Ept2
								! ea1 = [eaT(1,1),eaT(2,2),eaT(3,1),eaT(4,2)]
		Pt_df(1,pt) = RK_a*Pt_df(1,pt) + dt*( invM_R(1,Ept)-ea1(1)*invM_S1_f(1))
		Pt_df(2,pt) = RK_a*Pt_df(2,pt) + dt*( invM_R(2,Ept)-ea1(2)*invM_S1_f(2))
		Pt_df(3,pt) = RK_a*Pt_df(3,pt) + dt*( invM_R(3,Ept)-ea1(3)*invM_S1_f(3))
		Pt_df(4,pt) = RK_a*Pt_df(4,pt) + dt*( invM_R(4,Ept)-ea1(4)*invM_S1_f(4))
		Pt_df(5,pt) = RK_a*Pt_df(5,pt) + dt*( invM_R(5,Ept)-eaT(5,1)*invM_Sx_f(1)&
														   -eaT(5,2)*invM_Sy_f(1))
		Pt_df(6,pt) = RK_a*Pt_df(6,pt) + dt*( invM_R(6,Ept)-eaT(6,1)*invM_Sx_f(2)&
														   -eaT(6,2)*invM_Sy_f(2))
		Pt_df(7,pt) = RK_a*Pt_df(7,pt) + dt*( invM_R(7,Ept)-eaT(7,1)*invM_Sx_f(3)&
														   -eaT(7,2)*invM_Sy_f(3))
		Pt_df(8,pt) = RK_a*Pt_df(8,pt) + dt*( invM_R(8,Ept)-eaT(8,1)*invM_Sx_f(4)&
														   -eaT(8,2)*invM_Sy_f(4))
		end associate
	end do! Ept
	end associate
end do! i
On standalone tests, the above version did work!!! So do I make the correct change?
It can save 30% time compared with the original one (both compiled with /QxCORE-AVX2 and running on i7-7400)
But when I integrate it into my whole program, I found this part gives little gains... It is weird.( Maybe still my fault!)
So I wonder :
1. Is there anything else that I should pay attention to when targeting vectorization?
2. Apart from the current modification, is it possible to use ' matmul' or BLAS routines to achieve better performance and how?
jimdempseyatthecove
5.025 Visualizações
Good job on converting hints to code.
If the post Ep2 loop code is not vectorizing completely then switch from
   real(8) :: eaT(5:8,2)
to
  real(8) :: eaT1(5:8), eaT2(5:8)
Additional hint:
I find it best to use VTune, and then look at the code bottlenecks in the Disassembly view.
You do not have to fully understand assembly code to assess if your temporaries are scalar or vector and/or registered/RAM.
Jim Dempsey
Xia__Brian
Principiante
5.021 Visualizações
I don t really understand why switching from 2D array to two 1D array will help?
Memory access should be continuous in both cases I guess?
Unfortunately, I almost know nothing about assembly codes.
When I use VTune, I find its help manual not detailed enough for me(freshman).
I guess I'll spend a long time to learn necessary knowledge before I can pin point the problem in my code using VTune...
Ulrich_M_
Novo colaborador I
5.009 Visualizações
Are you using OpenMP to parallelize your code? That makes a huge performance difference, and is not difficult to do.
Xia__Brian
Principiante
4.998 Visualizações
Of course, OpenMP has been used on outmost loop and I have already reached a fairly good parallel efficiency even on NUMA arch.
What I want to discuss here is about vectorization and Cache.
I recently read an article also written by Jim:
Superscalar programming 101 (Matrix Multiply) Part 3 of 5
then and I realize there is stil a lot of potential on single core performance.
However the tricks in that article seem still difficult for me to undertand and use so far.
Ulrich_M_
Novo colaborador I
4.953 Visualizações
If you use OpenMP, and Dx and Dy are large, then the bottleneck might well be (relatively slow) RAM access due to cache misses. You might want to experiment with the number of parallel threads to empirically find the optimum for your application.
kay-diederichs
Novo colaborador I
4.703 Visualizações
I agree with Ulrich: memory access may be the bottleneck. Just try REAL(4) instead of REAL(8). It may be twice as fast.
Xia__Brian
Principiante
4.649 Visualizações
Yes, Dx is really a large block matrix and in parallel processing, each thread is trying to access different part of Dx at same time.
This can cause large bandwidth requirement.
Some story behind the codes:
On the old machine with single-channel DDR4,  RAM access is once a real problem.  To deal with it, I tried buiding the each Dx(i) matrix at runtime (whenever it is used) instead of pre-computing & storing the entire one. It requires fewer data access but apparently increase the computing effort!  So you see it is no more than a trade-off.
Later, I upated the computer and add multi-channel RAM.  the bandwidth is improved. Then I found the present version seems more profitable.  The old version is abandoned.
Even with real(8), the code so far is still not very likely to make full use of AVX256 / AVX512 at all time.
plus the fact that memory access issue is not so severe now,  using real(4) can only give about 15% speedup depending on applications.
jimdempseyatthecove
5.003 Visualizações
The suggestion was: If the...
While in abstract terms the two methods should be equivalent, the compiler optimization code may (potentially) miss the optimization opportunity. IF that is the case, then by simplifying the source code (2D array to two 1D arrays) may yield the desired results.
VTune is an invaluable tool to identify bottlenecks in your code. You do not need to learn "All about VTune" to get started. Start with
Collect Hot Spots
View Bottom-Up (lists hottest procedures in descending order)
Double-Click on top (hottest) procedure to view source
If interested, click the Assembly window to view assembly side-by-side.
While learning all about VTune is complicated, the basics is quite easy.
Jim Dempsey
Xia__Brian
Principiante
4.997 Visualizações
It seems swiching form 2D to 1D does not make difference in my case here.
I will try more VTune to see if I can get something new. And I'll update if I have problem.
Thanks for your reply!  It does help a lot!
jimdempseyatthecove
4.692 Visualizações
While the compiler optimization should have caught this, replace the associate pt and pt2/end associate with the fetch of the index into ipt and ipt2. This might save a little bit of overhead.
! derived type
end type
! temporary array
integer         iNp, ipt, ipt2
! main loop
do i = 1, ELE_num
  iNp = ELE_Ept_num(i)
  do Ept = 1, iNp
    invM_Sx_f = 0.0
    invM_Sy_f = 0.0
    invM_S1_f = 0.0
    do Ept2 = 1, Np
      ipt2 = ELE_EP2P(Ept2,i)
      block
        real(8) rDxDyDxDy(4)
        rDxDyDxDy(1) = Dx(i)%matA(Ept2,Ept)
        rDxDyDxDy(2) = Dy(i)%matA(Ept2,EPt)
        rDxDyDxDy(3:4) = rDxDyDxDy(1:2)
        invM_S1_f = invM_S1_f + rDxDyDxDy*Pt_f(1:4,iPt2)
        invM_Sx_f = invM_Sx_f + rDxDyDxDy(1)*Pt_f(5:8,iPt2)
        invM_Sy_f = invM_Sy_f + rDxDyDxDy(2)*Pt_f(5:8,ipt2)
      end block
    end do ! Ept2
    ipt = ELE_EP2P(Ept,i)
    Pt_df(1:4,ipt) = RK_a*Pt_df(1:4,ipt) &
                     + dt*( invM_R(1:4,Ept)-ea1(1:4)*invM_S1_f(1:4))
    Pt_df(5:8,ipt) = RK_a*Pt_df(5:8,ipt) &
                     + dt*( invM_R(5:8,Ept)-eaT(5:8,1)*invM_Sx_f(1:4) - eaT(5:8,2)*invM_Sy_f(1:4))
  end do! Ept
end do! i
Something like the above (untested) code.
Jim Dempsey
Xia__Brian
Principiante
4.656 Visualizações
Hi  Jim
Define temperary array within block construct...emmm....  it is really fresh to me!
I have tested your codes but it seems no improvement and even a little bit slower than the previous version.....
Adding Block and temperaray storage of Dx Dy in the innermost loop seems harmful.....
By the way, I always compiled with O3 option.
I guess the compiler should have detected the same reference and fetch it from cache rather than RAM after its first reference.
So there is no need to do these things manually.
jimdempseyatthecove
4.633 Visualizações
RE: O3
I assume you also included /QxCORE-AVX2
RE: Block
The intention of block is to declare a local temporary four element array in hope that the compiler will registerize it. From your test it appears that it did not.
 RE: fetch it from cach
The compiler has little to do with cache. That is a memory hierarchy issue. In the attempt at using block rDxDyDxDy end block the compiler could have constructed the 4-wide array in register, but apparently did not (resulting in a store, store, store, store, load). I am not faulting the compiler writers as they do an excellent job at optimization. This specific case may be new to them and/or of low priority.
Jim Dempsey
Xia__Brian
Principiante
4.622 Visualizações
So far, Mannully unrolling the innermost, incontinuous 'alpha' loop gives fairly good performance.
Even though it lookes redundant.
but It's hard to apply this pattern to other similar tasks in my application where the 'alpha' list varies with differerent element 'i'.
for example, the most direct way to implement variable 'alpha' list is to use a array 'alphaList' and a innermost 'ia' loop to access the 'alpha'
!(1) indirect access to alpha:  very slow
do Fpt = 1, Nfp
   do ia= 1, alphaListSize
        FLux(ia)=...
   end do
   do Ept = 1, Np
            invM_R(alphaList(ia),Ept)= invM_R(alphaList(ia),Ept) + Array(Ept,Fpt)*FLux(ia)
       end do
   end do
end do
!(2) static unrolled: fastest,  but not general
do Fpt = 1, Nfp
   FLux(1)=...
   FLux(2)=...
   FLux(3)=...
   FLux(4)=...
   do Ept = 1, Np
       invM_R(1,Ept)= invM_R(1,Ept) + Array(Ept,Fpt)*FLux(1)
       invM_R(2,Ept)= invM_R(2,Ept) + Array(Ept,Fpt)*FLux(2)
       invM_R(5,Ept)= invM_R(5,Ept) + Array(Ept,Fpt)*FLux(3)
       invM_R(6,Ept)= invM_R(6,Ept) + Array(Ept,Fpt)*FLux(4)
   end do
end do
!(3) evaluate all alpha even though some are unnecessary: slower than (2)
do Fpt = 1, Nfp
   FLux(1:8)=...
   do Ept = 1, Np
       invM_R(1:8,Ept)= invM_R(1:8,Ept) + Array(Ept,Fpt)*FLux(1:8)
   end do
end do
the above is only a sample. In the real task the alphaList may be much more complicated.
Is there any solution to it? Or do I get stuck in the wrong direction?
jimdempseyatthecove
4.610 Visualizações
In your !(2), I would suggest you experiment with exchanging the indices of invM_R (unless the performance order is important elsewhere).
The order you use there results in strided read/modify/write.
Jim Dempsey
Responder
