29278 Discussions
How to print real numbers left-padded with zero?
intelgg
The format i4.4 would print the integer number 12 as "0012". What format would print the real number 12.3 as "0012.3"?
There is no Fortran format that will do this - sorry. If you need this, you'll have to write into a character variable using internal write and then "post-process" the string replacing leading blanks with zeroes.
Steve
intelgg
Thanks Steve
Can users define new formats?
I can print the real number x = 12.3 as "0012.3" by doing
write(*, '(i4.4,f2.1)') floor(x), x - floor(x).
Can I define a format MY_FORMAT so as to
achieve the same result with
write(*, MY_FORMAT) x?
kdkeefer
You can set a character variable to your format code and reference the character string as your format statement.
(It's in the LRM).
Keith
intelgg
Thanks kdkeefer,
I am afraid your message does address
the issue I am raising.
Note that the format '(i4.4,f2.1)' takes two
inputs, which in my usage happen to be related.
The format MY_FORMAT I am seeking would achieve
the same result with just one input.
(By the way, what is LRM; what does this acronym mean?)
LRM = Language Reference Manual.
No, you cannot invent your own format codes. You could write a function that returns a character result with the value formatted as you like (then display it with the A format.)
Steve
