How to read numbers from a string
haijunwu
Hi, I met a problem in reading file.
Suppose the following string is what I want to read
"The first is an integer:100 and the second is a real 200.00"
what I am sure is that the first number is an integer and the second numberis real which are randomed distributed in a sting.
Thanks in advance!
bmchenry
New Contributor II
Basically youread and parse...
read the line in as a string.
Thenparse the string looking for numbers 0-9 and any period '.' (or comma ',') in the collection of numbers
once found,
write the numbers to a separate string (or keep track where in the string they are located)
read until a space or something other than 0-9, . (or ,) is encounterd
if a period (comma)is in the collection of digits (or simply after) it is a real number.
if no period (comma)it is an integer.
Then 'read' the string as either a real or integer number
move on to the next line!
JVanB
Valued Contributor II
Don't forget the leading sign on -100 and the sign of the exponent in +6.626e-34.
Check for trailing junk: 100 .01 Get 100's of prescription meds COD!
The first number is 47.100 is the second number.
Also 600 700 looks like valid input.
Also 600 7e2 should be OK.
Do you allow 600 7.0d2?
Or even 600 7.0q2?
Try 600 700.00.
onkelhotte
New Contributor II
We use this function for converting a string into an real. The number will be deleted from the string as well. When you read an integer, just perform
[bash]myInt = int(charzahl(string))[/bash]
I know its bad code, a former colleague wrote this years ago...
Markus
[bash]! **********************************************************************
      real(kind=4) function CHARZAHL (TEXT)
      CHARACTER*(*) TEXT,T*1,tt*30
      real(kind=4)  x
	  integer(kind=4) l, i
      L=LEN(TEXT)
1     if(TEXT(:1).GE.'-'.AND.TEXT(:1).LE.'9'.AND.TEXT(:1).NE.'/')GOTO 2
      TEXT=TEXT(2:)
      L=L-1
      if(L.GT.0) GOTO 1
      CHARZAHL=0.
      RETURN
2     I=1
3     I=I+1
      if(I.GT.L) GOTO 4
      T=TEXT(I:I)
      if(T.EQ.'.'.OR.T.GE.'0'.AND.T.LE.'9'.or.t.eq.'e') GOTO 3
4     I=I-1
      tt=text(:i)
      READ (tt,*,err=5) x
      CHARZAHL=x
      if(I.LT.L)then
         TEXT=TEXT(I+1:)
      ELSE
         TEXT=' '
      ENDIF
      RETURN
5     charzahl=0.
      return
      END function CHARZAHL
[/bash]
mecej4
There are at least two problems with this code.
1. It will not read integers with more than 24 significant bits correctly. Try this program:
[fxfortran]      program tst
        character(len=10) :: str='1234567890'
        integer :: i
        real charzahl
        i = int(charzahl(str))
        write(*,*)' i = ',i
        stop
      end program tst
[/fxfortran]
2. It returns 0.0 when the input number is 0.0 OR when an occur occurs. Therefore, if the input may contain 0.0, an input error will go undetected and the results will be erroneous.
onkelhotte
New Contributor II
Hi mecej4,
thanks for the advice with high integer values. This error wasnt noticed in our departement over nearly 2 decades :-)
The behaviour, that the function return an 0.0 when the is an error, the string has no number or the string is actually 0.0: Thisis intended. But do youhave an idea howto filter an error? Maybe using HUGE for an error?
Markus
      real(kind=4) function stringToReal (TEXT)
      CHARACTER*(*) TEXT,T*1,tt*255
      real(kind=4)  x
      L=LEN(TEXT)
      TEXT=TEXT(2:)
      L=L-1
      if(L.GT.0) GOTO 1
      stringToReal=0.
      RETURN
2     I=1
3     I=I+1
      if(I.GT.L) GOTO 4
      T=TEXT(I:I)
4     I=I-1
      tt=text(:i)
      READ (tt,*,err=5) x
      stringToReal=x
      if(I.LT.L)then
         TEXT=TEXT(I+1:)
      ELSE
         TEXT=' '
      ENDIF
      RETURN
5     stringToReal=0.
      return
      END function stringToReal
      integer(kind=4) function stringToInt (TEXT)
      integer(kind=4)  x
      L=LEN(TEXT)
      TEXT=TEXT(2:)
      L=L-1
      if(L.GT.0) GOTO 1
      stringToInt=0.
      RETURN
2     I=1
3     I=I+1
      if(I.GT.L) GOTO 4
      T=TEXT(I:I)
      if(T.GE.'0'.AND.T.LE.'9') GOTO 3
4     I=I-1
      tt=text(:i)
      READ (tt,*,err=5) x
      stringToInt=x
      if(I.LT.L)then
         TEXT=TEXT(I+1:)
      ELSE
         TEXT=' '
      ENDIF
      RETURN
5     stringToInt=0
      return
      END function stringToInt[/bash]
mecej4
>Thanks for the advice with high integer values. This error wasnt noticed in our department over nearly 2 decades :-)
Well, it is likely that in the applications that it was designed for and in which it was frequently used, integers larger than that limit were never encountered (or were encountered but the consequent error was not noticed!) -- somewhat like using two-digit years and the Y2K problem.
I am curious to know if this function was used extensively on computers that used different floating point representations than IEEE-32 bit (e.g., IBM mainframe, VAX, etc.)
If returning 0.0 when an error occurs is intended and acceptable, all that you have to do is to add a suitable comment to the source code, especially when you give it to others.
A better solution would be to set the result to NaN (or, if you prefer, HUGE), provided this is again advertised as a comment in the code and the user can check for such values. Otherwise, an error message should be printed, in a fashion similar to assertions in C/C++ code.
It is probably feasible to run tests for at least the integer conversion to see if the correct output is given for all possible inputs.
Please note that kind numbers, as in 'kind=4' are not portable.
jimdempseyatthecove
I agree with mecej4's recommendation of returning NaN since this value is "sticky" and should draw attention to "no value".
However, this may cause problems unforseen by us non-users of your application.
For instance, the input data may be arriving from an input text parameter file, when some user may have had:
123 Along with comment
456 more comments
0 Zero here
Text Here formerly returning 0.0
789 more data
Additionaly, by previous convention, an input line with no data (blank line) may be interpreted as 0.0 by your input parser.
Note, if NaN is not appropriate, you could consider returning -0.0
RetVal = TRANSFER(Z'80000000',RetVal)
Or return TINY or -TINY or HUGE or -HUGE as mecej4 also suggests
Therefore, you will have to check your input files as well as the code to see how it handles "comment text" embedded with the data.
Jim Dempsey
nvaneck
This one works....
REAL(8) FUNCTION DCONV(STRING,IERR)
IMPLICIT NONE
CHARACTER(LEN=*) STRING
LOGICAL IERR,NEG,IFDEC
INTEGER(4) I,L,J,NDEC,IEXP,ICONV
INTEGER(4),PARAMETER :: PERIOD=-2,MINUS=-3,PLUS=-5,BLANK=-16
DCONV=0D0
NEG = .FALSE.
IERR = .FALSE.
IFDEC = .FALSE.
L=LEN_TRIM(STRING)
DO I=1,L
J=ICHAR(STRING(I:I))-48
IF (J .GE. 0 .AND. J .LT. 10) THEN
DCONV=DCONV*10D0+J
IF (IFDEC) NDEC=NDEC+1
ELSEIF (J.EQ.MINUS .AND. DCONV .EQ. 0D0 .AND. .NOT. IFDEC .AND. I .NE. L) THEN
NEG = .TRUE.
ELSEIF (J .EQ. PERIOD) THEN
IF (IFDEC .OR. L .EQ. 1) GO TO 40
IFDEC=.TRUE.
NDEC = 0
IF (DCONV .EQ. 0D0 .AND. I .EQ. L) THEN
IF (L.EQ.1) GO TO 40
IF (STRING(I-1:I-1) .NE. '0') GO TO 40
ENDIF
ELSEIF (STRING(I:I) .EQ. 'E' .OR. STRING(I:I) .EQ. 'D') THEN
IF (I .EQ. L) GO TO 40
IEXP=ICONV(STRING(I+1:L),IERR)
IF (IERR) GO TO 40
DCONV = DCONV*(10D0**IEXP)
EXIT
ELSEIF (I .EQ. L .OR. DCONV .GT. 0D0 .OR. (J .NE. BLANK .AND. J .NE. PLUS)) THEN
GO TO 40
ENDIF
END DO
IF (NEG) DCONV = -DCONV
IF (IFDEC) DCONV=DCONV/(10D0**NDEC)
RETURN
40 IERR = .TRUE.
50 DCONV=1600000000D0
END
