How to reduce the code?
Ivan_S_
How to reduce the following code?
[fortran]P0=1.D0
DO I=1,6
  DO J=1,6
    S(J,I)=P0
  END DO
END DO[/fortran]
I am looking for the simple solution for the following array:
[fortran]| 1.D0 1.D0 1.D0 |
| 1.D0 1.D0 1.D0 |
| 1.D0 1.D0 1.D0 |[/fortran]
mecej4
If S is not dimensioned (6,6), but something larger: S(1:6,1:6) = 1d0
rase
Even shorter:  s=1d0
complete program:
real(8), dimension(6,6) :: s
s=1d0
end
Ivan_S_
S is dimensioned as (6,6). Both variants are working excellent. Thanks!
John_Campbell
New Contributor II
Even "s=1" will give the correct result, as 1d0-1 = 0
