29635 Discussions
How to set stack size while building in sublime text?
Yeldon_Y_
I've got this problem while I am trying to build fortran in sublime text.
Here is what I wrote in sublime text. It works well except for stack size. When I am trying to compile, it says
ifort: command line warning #10006: ignoring unknown option '/stack:0×1500000000'
Here is my code in sublime, if someone would like to help me with it.
  "cmd": ["cmd", "/e:on", "/v:on", "/c","ipsxe-comp-vars intel64 vs2012 && ifort  ${file} -stack:0×1500000000" ],
    "file_regex": "^.*\\\\([0-9A-Za-z_]+\\.[A-Za-z0-9]+)\\(([0-9]+)\\):[ ]+error[ ]+#([0-9]+):[ ]+(.*)$",
    "working_dir":"${file_path}",
    "selector":"source.f ,source.for ,source.ftn ,source.f90 ,source.fpp ,source.i ,source.i90",
    "encoding":"cp936",
    "path":"C:\\Program Files (x86)\\Intel\\Composer XE 2013\\bin;${path}",
    "variants":
              "name": "Run",
              "cmd": ["cmd", "/e:on", "/v:on", "/c", "ipsxe-comp-vars intel64 vs2012 && ifort ${file} && ${file_base_name}"]
JVanB
Valued Contributor II
I see two possible problems. First, I think ifort needs a -link switch before the -stack:0x1500000000 switch. Also, your 0x is coming out more like 0× a multiplication operator rather than the letter x. Try to make sure that's not an issue.
mecej4
The compiler and the linker do not use the same syntax for specifying the stack size. You can use the /link switch as Repeat Offender stated or you can use the compiler's format:
      /F<n>     set the stack reserve amount specified to the linker
