29560 Discussions
How to set up a function to be called from vb.net 2005
john_lott
What is the proper format to export a function for use in another language ? Also is there a requirement for byte alignment when using structure.
My sample function might be to take a integer(4) as a parameter, double it and return the value.
Thanks in advance
John
Have you looked at the VB--Calls-Fortran sample provided?
As for structures, if you are sharing a structure with another language you will need to understand how that language (VB or whatever) lays out the structure. On the Fortran side, I recommend giving the corresponding derived type the BIND(C) attribute for maximum interoperability. You can deal with any alignment yourself.
