Hi every body,
I am a C++ programmer and new to fortran. Could you please let me know how I can slip a long Fortran code in to multiple files, like what we normally in C++ by include?
Thank you,
Fortran provides the following statement (surprise!)
include character-literal-constant
However, splitting a big source code into chunks and 'include' segments is probably not a good style of programming, and may create many headaches. Consider using modules instead.
Some Fortran compilers, including Intel Fortran also provide C-style preprocessors.
Fortran supports MODULE syntax, "to group related procedures and data together," along with both its own form of INCLUDE and, for most compilers, a C-compatible form.
Thank you! Since I am using this fortran program for ABAQUS (a modeling software), it is necessary the output to be just one obj file. So if I use module, it will be split into multiple obj files. I am not sure if include can help me or not in this regard which is aridiculousness of that modeling software. Shame on its developers! Do you have any other idea?
Thanx!
Just do it with INCLUDE as you do in C++.
include 'file1.f90'
include 'file2.f90'
include 'file3.f90'
etc.
include 'file1.f90'
include 'file2.f90'
include 'file3.f90'
etc.
Thanx! But it gives me an error as I have introduced a subroutine in the first line of the included file. Anyway, I could solve the problem by changing the project type from a stand-alone to static link library, so all objs are now included in a lib / obj file, which is usable for the modeler software.
Odd - I can't think of a reason why you should get an error assuming each file was compilable on its own. Can you attach a ZIP of an example?
