29429 Discussions
How to statically link libiomp5md in IVF 11.0?
Greynolds__Alan
I want to create a standaloneOpenMp application in IVF 11.0 but even with /static the exe still needs to find libiomp5md.dll.
Al Greynolds
www.ruda.com
pbkenned1
There's more involved than just compiling with /Qopenmp here. If you want to link against the static OpenMP RTL, you must add /Qopenmp-link:static, which is a new switch for 11.0. So to produce a purely static executable, compile/link with /MT /Qopenmp-link:static /Qopenmp
The 11.0 Windows compilers (both C++ and Fortran) have decoupled /MT from having any effect on which OpenMP runtime (static or dynamic) gets linked. In fact, all of /MT, /MD, and /ML (latter VS2003 only) now only effect which MS C runtime is linked.
We made this change because we want dynamic to be the default when linking the OpenMP RTL. The use of static OpenMP libraries is not recommended, because they might cause multiple libraries to be linked in an application. The condition is not supported and could lead to unpredictable results. It can also cause Thread Checker false positives and other problems with the Intel Threading tools.
Patrick Kennedy
Intel Compiler Lab
Greynolds__Alan
Thanks Steve. Didn't think to look under /Qopenmp.
Al
pbkenned1
Quoting - layzarc@aol.com
Al
pbkenned1
Patrick Kennedy
Intel Compiler Lab
Steefel__Carl
Quoting - pbkenned
Patrick Kennedy
Intel Compiler Lab
Steefel__Carl
Quoting - Carl Steefel
Sorry about the double post, don't know what happened.
But the issue here is that many of us would like to distribute executables to non-computer types without also having to distribute the libiomp5md.lib. The people I give my code to are severely challenged by something as simple as an Environment Variable. Not impossible to deal with, but if one can minimize these extra dynamic libraries, it helps.
Speaking of which, I cannot get the OpenMP to link statically in any case. I built the PETSc library using the link flags
/Qopenmp-link:static /Qopenmp /MT
then built my Intel Visual Fortran project (Intel 11.1.046) using the same thing as additional options in the Command Line (for Fortran and Link). I don't see anywhere else to include this.
When I transfer the executable to another Windows PC, I get the message that libiomp5md.dll is missing, and this is fixed by dropping in this library in next to the executable. Anyway, it seems as if the /Qopenmp-link:static is being ignored???
DavidWhite
Valued Contributor II
To avoid having to statically link the libraries, have you thought about packaging the files for your users into an installer? I use NSIS (available from sourceforge.net) - this isopen source and available for use both commercially and personally.
Steefel__Carl
Quoting - David White
Yes, I believe this is the way to go. I used to do this in the past, then quit doing it when so many people had trouble downloading *.exe files (the Installers I used had this format). Maybe it is no problem again...
