How to transfer a licence
mark_murphyriotinto_
I have fortran for windows installed on one machine and I need to move it to another. How do I go about doing this?
Kevin_D_Intel
Copy the actual license file (.lic) from C:Program FilesCommon FilesIntelLicenses from the current machine into a temporary location on the new system. Then run the compiler installation on the new system and when prompted direct the installation to the temporary copy of the license. The installation will proceed and also place a permanent copy of the license in the location mentioned. After the installation completes you can delete the temporary copy of the license.
You could also just install on the second machine using a serial number. Note that our compiler licenses typically allow you to install on as many systems as you want, as long as you are the primary user. The exception is a "node-locked" license which we no longer sell, but customers may have bought previously.
Of course, if you are no longer going to use the old system, you should remove the license from it. The Intel licenses are placed in C:Program FilesCommon FilesIntelLicenses
Kevin_D_Intel
Thanks for adding/clarifying Steve.
Please excuse the extra steps Mark. My brain was stuck in "I can't install using the Serial number, what do I do?" mode this morning.
sgtmfd
I have experienced problem when re-installing Fortran with 'node-locked' license - in the same PC in order to add some missed installation option.
When I tried to fill the serial number to the linked website during re-installation, it was failed (invalide key/serial number). How to solve this problem ?
Daus.
Node-locked licenses require a license server - if you were simply reinstalling, the install should have found the license server and suggested that as the default. If it didn't, select the option to use a license server. Serial numbers won't work if the serial number was issued when an earlier version was current, but license files will work.
If you need more help, please ask in our Licensing forum section.
Jack_O_
Ive got a problem with a licence transfer.
Ive been given a licence number and a licence file for Intel Visual Studio. Yet, I can't complete the installation (either with internet connection or using the licence file).
Could you please help me with that ?
Thank you,
Jack Owen
Jack_O_
Thank you.
I sent my message overthere
http://software.intel.com/en-us/forums/topic/501975
but nobody has answered me yet.
I put a reply in over there.
