29429 Discussions
How to uninstall the intel fortran 11.1?
truelies
I want to uninstall the 11.1 edition and install the XE. I think I did wrong by first uninstalled that vs2008 shell, then I can't uninstall the intel fortran. What can I do to uninstall the Fortran?
truelies
Ok, after several try, I think I have uninstalled the 11.1 My other question is, the previous edtion intel fortran was expired, I just bought a new license. How to change the license number to the new one? After uninstall I think the license number still stored in the computer.
Ron_Green
You can keep the old license file around OR you can move it out of the way. I would not delete it, but rather copy it to a backup directory.
On 32bit Windows systems, It is stored in folder c:\Program Files\Common Files\Intel\Licenses\ For 64 bit x64 Windows versions, same path but c:\Program Files (x86)\...
If you have the .lic license file for the new compiler, copy it to that Licenses\ folder.
ron
Wendy_Doerner__Intel
Valued Contributor I
I suspect you may have purchased a license renewal. If that is the case, here are instructions on how to apply it to your exisiting license.
http://software.intel.com/en-us/articles/make-renewal-applied-to-right-license/?wapkw=(license+renewal)
It sounds like you have uninstalled 11.1 and now just need to install the Intel Visual Fortran Composer XE. It does contain VS2008 shell. Can you let us know if you are having problems with the install at this point?
Wendy
Attaching or including files in a post
