The intrinsic function ACOSH with complex argument was added to Fortran in Fortran 2008. Since this function is multi-valued for complex arguments, a convention is needed for what the return value should be. The F2008 (13.7.5) and F2018 (16.9.5) standards state:
5 Result Value. The result has a value equal to a processor-dependent approximation to the inverse hyperbolic cosine function of X. If the result is complex the imaginary part is expressed in radians and lies in the range 0 ≤ AIMAG (ACOSH (X)) ≤ π
In contrast, the Intel Fortran Development Reference Guide says:
If the result is complex, the real part is non-negative, and the imaginary part is expressed in radians and lies in the range -pi <= AIMAG (ACOSH (x)) <= pi.
The following program outputs a result with the imaginary part negative:
program xacosh
implicit none
complex :: z = (-0.01, -0.01)
print 10, 'z', z, 'acosh(z)', acosh(z)
10 format(1x,A,T10,'( ',ES11.3,' , ',ES11.3,' )')
end
The result:
S:\LANG\ftn95>acosh
z ( -1.000E-02 , -1.000E-02 )
acosh(z)( 1.000E-02 , -1.581E+00 )
Please clarify if the deviations ( w.r.t. (a) sign of the real part and (b) range of the imaginary part) from the standard are deliberately intended, and any reasons for the choices, if available. Thank you in advance.
D:\Projects>nagfor -o t.exe t.f90
NAG Fortran Compiler Release 7.1(Hanzomon) Build 7114
[NAG Fortran Compiler normal termination]
D:\Projects>t.exe
It's an error in the F2018 standard, corrected by interpretation request F18/0001. The corrected text says, "If the result is complex the real part is nonnegative, and the imaginary part is expressed in radians and lies in the range −π ≤ AIMAG (ACOSH (X)) ≤ π"
This is really fascinating, the https://www.geeksforgeeks.org/acosh-function-for-complex-number-in-c/ site seems to agree with your Intel observations. They provide a couple of quick samples.
Running their sample but with the -0.000 I get -pi.
-1.58 is just 335 degrees in the -PI to PI system.
This is an interesting one. gfortran 12.0.1 is in agreement in values with ifort/ifx. I will ask advice from someone more familiar with this function, and the F08 Standard. I don't have the NAG compiler myself but I'll ask someone to try it with NAG.
D:\Projects>t.exe
The portion "the imaginary part is expressed in radians" strikes me as odd, since the imaginary part (with the i removed) does not represent an angle -- it is just a real number.
If one wishes to think about the Argand Diagram, the real part is the x-coordinate and the imaginary part is the y-coordinate. It is only after the point (x, y), where z = x + i y, is plotted and a line drawn to it from the origin that we may speak of angles.
