29435 Discussions
I cannot install the l_fc_p_10.0.023_intel64
freemanty
System: Intel 64bit, Ubuntu 7.04
Two problems:
first: After ./install.sh, I was told I need g++. But after installing g++, here is the error:
/opt/l_fc_p_10.0.023_intel64/./osdetect.sh: line 273: /opt/l_fc_p_10.0.023_intel64/data/chklic.em64t: No such file or directory
ERROR: Problem encountered executing CHKLIC_32_64 utility located here:
The CHKLIC_32_64 program data/chklic.em64t requires these libraries:
not a dynamic executable
Atucally, the file chklic.em64t is sitting just there.
So, I have to remove the g++ package to preceed without it, then
here is problem 2:
S/N doesn't work, I tried to downlond the license file and gave the path and filename:
Invalid license file
Thanks!
TimP
I believe Ubuntu poses special obstacles to installation of 64-bit development tools. You should follow up previous references on this forum, for example.
You need more than the 64-bit g++ development environment; ifort requires at least the 32-bit libstdc++ compatibility shared library, and a means to discover what path it is installed on. The expectation would be that 'g++ -m32 -print-search-dirs' would show this path.
After getting the gnu components in place, you will may have to repeat the ifort installation.
There are known problems installing 10.0 on Ubuntu, and that is not a supported distribution for 10.0. I do not know if there is a way to work around the problems at this time. We will support Ubuntu in an update later this year.
j4play
maybe this thread might help:
http://ubuntuforums.org/showthread.php?t=508778
as per my post in that thread, installing lib32gcc1 seemed to fix this for me.
