29486 Discussions
Question on INTERFACE Block for Calling C++ Function from Fortran
rforehan
I'm new to Intel's Fortran compiler v10. My past experience was with F90/F95 with Absoft compiler on Linux box. I'm trying to define the Fortran interface to the following C++ function compiled using MS VS 2005 on WinXP x64 box:
typedef int ExitStatus;
typedef void* OoModtranHandle;
extern ExitStatus __stdcall SETCARD2C1(OoModtranHandle h,
float *zm,
float *p,
float *t,
float *wmol2c1[],
char *pType,
char *tType,
char *mType[],
int ml,
float *wmol2c2[],
float *wmol2c2x[],
char *mXType);
Any assisstance would be greatly appreciated
TimP
stdcall isn't supported on 64-bit Windows. Several options are documented in the doc folder in your ifort installation. As you would have to change it somewhat anyway, you might consider following the f2003 C interoperability examples.
g_f_thomas
If the C code is in a lib project to be called by IVF then interfaceare generated via /gen-interfaces andend up in the F90's folder as X.mod.f90's.
Gerry
Gerry, I read your comment as saying that Fortran interfaces to C code are created with /gen-interfaces. That is not the case.
Tim is correct that x64 does not support __stdcall, though I think you can still use the keyword.
g_f_thomas
Silly me, you're quite right, Fortran can generate interfaces for its own functions and not for C and these have to be hand rolled.
Incidentally, why do the Fortran interfaces ignore INTENT? It would handy if they handled this attribute.
Any chance of a basic sample on C interop?
Gerry
In what way do you see INTENT ignored? Example? What do you expect to happen that doesn't?
Yes, a sample using the C interop features would be a good idea - I also plan to write a "Dr. Fortran" article about it.
Let's see if I can suggest what an interface to SETCARD2C1 would look like....
interface
function SETCARD2C1 (h, zm, p, t, wmol2c1, pType, tType, mType, &
ml, wmol2c2, wmol2c2x, mXtype)
use ISO_C_BINDING
integer(C_INT) :: SETCARD2C1
!DEC$ ATTRIBUTES STDCALL,REFERENCE,DECORATE,ALIAS:"SETCARD2C1" :: SETCARD2C1
type(C_PTR), intent(INOUT) :: h
real(C_FLOAT), intent(INOUT) :: zm
real(C_FLOAT), intent(INOUT) :: p
real(C_FLOAT), intent(INOUT) :: t
real(C_FLOAT), dimension(*), intent(INOUT) :: wmol2c1
character(*), intent(INOUT) :: pType
!DEC$ ATTRIBUTES REFERENCE :: pType
character(*), intent(INOUT) :: tType
!DEC$ ATTRIBUTES REFERENCE :: tType
character(*), intent(INOUT) :: mType
!DEC$ ATTRBUTES REFERENCE :: mType
integer(C_INT), VALUE, intent(IN) :: ml
real(C_FLOAT), dimension(*), intent(INOUT) :: wmol2c2
real(C_FLOAT), dimension(*), intent(INOUT) :: wmol2c2x
character(*), intent(INOUT) :: mXType
!DEC$ ATTRIBUTES REFERENCE :: mXType
end function SETCARD2C1
end interface
To explaijn some of this. The ATTRIBUTES directive for the function is strictly not needed on x64, but this will ensure portability to IA-32 if need be. The character arguments need the REFERENCE attribute for each one to prevent a length from being passed. I added INTENT attributes from guesses, but I'd recommend changing these to IN or OUT where appropriate.
The "h" argument is declared in C as a pointer to VOID, or in other words, a "handle". There are various ways of representing this in Fortran but I chose to use type C_PTR, declared in ISO_C_BINDING, here. There are other choices, but this one is probably closest to the origiinal intent.
g_f_thomas
The module generated for
subroutine
for2 [Alias:'_for2'] ( i, r, c, d )
implicit none
complex, intent(inout) :: c[REFERENCE]
double precision, intent(inout) :: d[REFERENCE]
integer, intent(inout) :: i[REFERENCE]
real, intent(inout) :: r[REFERENCE]
< stuff >
return
end
, where theINTENT of all arguments is specified, is
!COMPILER-GENERATED INTERFACE MODULE: Wed Oct 03 11:55:33 2007
MODULE FOR2_mod
INTERFACE
SUBROUTINE FOR2(I,R,C,D)
INTEGER(KIND=4) :: I
REAL(KIND=4) :: R
COMPLEX(KIND=4) :: C
REAL(KIND=8) :: D
END SUBROUTINE FOR2
END INTERFACE
END MODULE FOR2_mod
in which there is no mention of INTENT.
Where are Dr Fortran newsletters available? I haven't seen one for eons.
Gerry
rforehan
Steve,
Thanks for the help. I do need togenerate both IA-32 and x64 versions of the code.All the variables are inputs to a wrapper we're using to connect some legacy Fortran with a new C++ version of MODTRAN. The example was the worst case interface.
I'm also interested in reading the Dr Fortran articles.
Thanks again,
Dick
Gerry,
You're using an old compiler version. With the current 10.0.027 I get:
!COMPILER-GENERATED INTERFACE MODULE: Wed Oct 03 13:33:21 2007
MODULE FOR2_mod
INTERFACE
INTEGER(KIND=4), INTENT(INOUT) :: I
REAL(KIND=4), INTENT(INOUT) :: R
COMPLEX(KIND=4), INTENT(INOUT) :: C
REAL(KIND=8), INTENT(INOUT) :: D
END SUBROUTINE FOR2
END INTERFACE
END MODULE FOR2_mod
However I notice that the alias you specified was not used - that's a bug and I'll report it.
A link to the continued adventures of Dr. Fortran is at the bottom of every one of my posts. Dick, you can read the older items here.
g_f_thomas
That's interesting. I have IVF 9.1 and 10.0.027 on VS2005. For the most part I only use the current version. Now I get the same interface as you do. The only way that I could have generated an interface without INTENT was that at the time of generation the function didn't have it specified and only when I deleted the debug folder and recompiled were the previous x.mod.f90's replaced. Now I know that it works as I expected (ie, with INTENT and all).
Gerry
